Question about Onkyo TX-NR828 7.2-Channel Network A/V Receiver
Onkyo receiver does not respond to anything but my remote app
Everything worked fine, but for some reason yesterday after using my onkyo remote app to control the receiver I was no longer able to use the normal remote and even the unit's buttons themselves were not responding. I couldn't get it to turn on, but after I disconnected everything and plugged it back in it works. The unit is still not responsive to anything but the app. Any ideas?
3 Suggested Answers
  • 979 Answers
SOURCE: Receiver doesn't respond on remote signals
Low batteries can cause a symptom like this. Have you tried to replace them yet?...accordianman
Posted on Oct 25, 2007
  • 14 Answers
SOURCE: onkyo SR605 Remote not working at all.
Dear Bzambo,
The batteries on the remote are fresh? if so the remote might be bad.
Sidlahora
Posted on Dec 06, 2007
Onkyo receiver will not respond to Onkyo remote
Hi Thomas, I am not aware of your model but try pressing the receiver button in the remote mode section or RCV on top depending on your receiver model. Thank you, Onkyo USA
Dec 25, 2016 | Onkyo Audio Players & Recorders
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
How to reset RC-569M remote controller to factory defaults.
Not sure if it's the same, but for the Onkyo RC-799M controller the reset sequence is:
To reset the remote controller to its factory defaults,
while holding down RECEIVER, press and hold down
HOME until the remote indicator lights (about 3
seconds). Within 30 seconds, press RECEIVER
again.
Jan 05, 2015 | Onkyo Audio Players & Recorders
We have "HT R670" and "HT R360" A/V Receivers with questions regarding Universal Remotes and Android Apps.
The Onkyo App will not work with the HT-R670. This receiver is part of the HT-S6200 Home Theater package and is not network compatible. You might be able to use the Logitech Harmony Hub and app or another remote control app paired with an IR repeater pointing at the receiver. Some universal remotes may support changing the inputs on the receiver. However, I don't know of any specific model that will work. The Logitech Harmony remotes are probably the most likely to support the Input button; it may take programming a specific button to match the receiver's Input function. If you need a replacement for the original remote, one source is https://www.amazon.com/OEM-Onkyo-Remote-Control-HT-S6200/dp/B0137R62H2 . The manual for the HT-S6200 is available here: http://www.intl.onkyo.com/downloads/manuals/pdf/ht-s6200_manual_e.pdf .
I can't find an Onkyo HT-R360 listed even as part of home theater system. There is an Onkyo HT-RC360. The manual for that is http://redirect.onkyousa.com/redirect_service.cfm?type=own_manuals&file=SN29400649_HT-RC360_En_web.pdf . While this model has a network connection, it is not compatible with the Onkyo app either.
Nov 11, 2017 | Audio Players & Recorders
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Apr 29, 2010 | Onkyo TX-DS575 Receiver
Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Sep 12, 2009 | Onkyo TX-SR606 Receiver
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Jul 06, 2009 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575X, remote intermittend malfunction
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
Oct 08, 2008 | Onkyo TX-DS575 Receiver
Onkyo SR605 Remote not working at all.
Dear Bzambo,
Sidlahora
Dec 06, 2007 | Onkyo TX-SR605 Receiver
Oct 04, 2007 | Onkyo TX-DS595 Receiver
Onkyo TX-NR828 7.2-Channel Network A/V Receiver Logo
13 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
