Question about KitchenAid KEHC379 Electric Double Oven
Shows front image of microwave in display
Does not heat but shows a small picture of microwave at left bottom of display. GE spacemaker xl 1800 model, 7 years old microwave.
I have a GE JKP86-27 oven. Neither the bake or broil work. Microwave works fine. Controls come on for oven.
I, too, have the GE -JKP86. Microwave over oven. My oven would not heat up on bake or broil. Elements checked good, no fault codes. This is how I fixed mine: Shut off power at the box. Remove unit from cabinet. I placed mine on a chair. Remove cover(s) until you expose the circuit boards behind the control consol . The top board is behind the microwave controls, the bottom is behind the oven controls. Remove the bottom board by removing 4 screws. I take pictures with my smart phone, even some video. Helps me remember how everything goes back together. BE SURE THE POWER IS OFF, HIGH VOLTAGE IN HERE! One of the screws is hard to see. It is behind the ribbon connector. Unplug everything carefully. You will see a red and an orange wire north and south of a small relay. You must unclip the circuit boards from each other. Look for a missing drop of solder on the back side of the board with the relay. You will find it underneath where the red wire connects. Mine ( looking through a magnifying glass) looked like a crater with a wire sticking up out of it. It had overheated and the solder dripped out. The joint is inadequate. I cleaned and resoldered it with a nice blob. Reassemble and check. I just left mine on the chair. Power on. Select bake, 300, start. You should here the relays click and after about 45 seconds you'll see the bottom element glow. After one minute the relay clicks again ant you'll see the top element glow. They alternate during the preheat cycle. Put it all back together and shove it all back in the hole. Hope this helped!
Oct 11, 2012 | GE JKP86 Electric Double Oven
Ge spacemaker microwave Model JVM1650BB003, Runs but does not heat and has a loud humming noise
Typically when that happens a part called the diode is bad. IT IS EXTREMLY ADVISED BECAUSE OF THE HIGH VOLTAGE AND REAL POTENTIAL FOR RADITATION THAT ONLY A PROPERLY TRAINED APPLIANCE TECHNICIAN REPAIR THAT
Gene
Aug 05, 2011 | Ovens
GE spacemaker microwave jvm 1450 stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 29, 2011 | Ovens
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
GE Je1590 microwave oven turns on nut not heating
heatman101
gf
Mar 01, 2010 | GE JE1590 Electric Single Oven
Convection works but Microwave does not heat
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
KitchenAid KEHC379 Electric Double Oven Logo
14 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
