Question about Polaris 2005 Classic 550
2005 polaris 550 classic left cylinder not firing
Left cylinder not firing, checked plugs, checked for fuel, checked for spark, and checked for compression by putting my thumb over the hole and felt the same as the right side. any suggestions
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
Hopefully it's just the spark plug, take it out and check the gap and coloring, clean it and set the gap to the recommended gap, Or take note of the spark plug code and get a new one, check with the manufacturer or in your handbook that it is in fact the correct one.
Check the connections and lead, they do deteriorate over time, to find out if your on the right track, swap the leads over and see if the other cylinder dose the same thing. Swap the spark plug over from the other cylinder for process of elimination. So if it's still missing we know to check the pickups or cdi unit, there's a possibility its fuel, check the carburetor, is it a twin carb? If so, clean it buy taking the bowl of and draining out the fuel, you should do this occasionally anyway. Check the fuel filter while you're at it.
Good luck
Posted on Feb 10, 2014
Have a 1999 snowmobile polaris 500 classic.will not fire.plugs are wet.tried removing fuel from cylinders with plugs out.reinstall plugs turn key turns over will not start
Did you try laying the plugs on the head and plug them into the wires, then crank it over and see if the plugs spark then. If they don't then maybe crank sensor or cdi box is bad.
Dec 29, 2016 | Winter Sports
How to bypass kill switch on 2005 polaris sportsman 500 ho
If it is firing with starter fluid it is probably not an electrical problem as that indicates you have spark at the plug check to make sure you are getting good spark continous if so the problem is in the fuel delivery process water in carb stuck float fuel line filter plugged etc
Oct 12, 2014 | Polaris ATV
1997 Kawasaki VN 1500 Vulcan Classic the engine is only firing on 1 cylinder
Hi, Anonymous you need "FIVE" things in order for a cylinder to run properly:
1. FUEL: in order to validate your not getting fuel spray some starting fluid into the air cleaner and hit the starter button, if it fires up and runs for a few seconds then you know you have a fuel delivery issue. Multi carb banks should be bench "SYNC"
2. SPARK: remove the spark plug and with it connected to the spark plug cable ground the threads to something metal you should see a bluish white spark if not you have a faulty spark plug, spark plug cable, ignition coil, condenser, CKP, ECM, sensor or the wiring in between.
3. COMPRESSION: you must have at least 80-100 PSI for most bikes, multi-cylinder engines should be within 10-15% of each other if not perform a leak down test you may have a burnt or bent valve or hole in the piston or broken rings.
4. CAM TIMING: confirm your timing marks are aligned to see if the cam chain or adjuster are worn out and the chain has skipped a couple teeth.
5. IGNITION TIMING: on older bikes check to see if your points have not closed up, timing plate has not become loose and confirm with a timing light for proper retard and advance functions, on newer bikes where timing is controlled by an ECM and is nonadjustable check you CKP, TPS, MAP, O2, sensor or its counterpart for integrity.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Front cylinder not firing on 1500 Kawasaki Vulcan Forum Vulcan Forums
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/102776-no-fire-rear-cylinder.html
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
1997 Kawasaki Vulcan 1500 Classic Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 01, 2014 | 1997 kawasaki VN 1500 Vulcan Classic
2001 Kawasaki VN 800 Vulcan Classic rear cylinder not firing
http://www.vn750.com/forum/11-vn750-general-discussion/23514-rear-cylinder-not-firing.html
KAWASAKI VN800 Service Manual
2001 Kawasaki Vulcan 800 Classic Owner Manual
Sep 04, 2012 | 2001 kawasaki VN 800 Vulcan Classic
How do you change spark plug wires on atv polaris 2003 700 sportsman
Spark plug wires on the Polaris twin engines are a one piece wire. They come with a connector on the coil end and a plug cap on the plug end. Both of the wires have to be ordered from a Polaris dealer. The coil is located under the front left fender and the connectors can be pulled out by hand. The cylinders fire at the same time so it is not necessary to pay attention to what wire goes to which cylinder. Hope this is what you needed, if not let me know. Daniel
Jul 19, 2011 | Polaris ATV
I have a 1995 polaris 600 triple it fires but does not want to keep running seems like not getting gas it will fire on full choke off it wont even fire
CHECK THE COMPRESSION OF THE ENGINE, IF IT IS AT ABOUT 120PSI AND DOES NOT HAVE A DIFFERENCE BETWEEN CYLINDERS OF 15% THAN CHECK YOUR FUEL PUMP. YOU DO THIS BY REMOVING THE SPARK PLUGS AND FUEL LINES TO YOUR CARBS AND PULLING IT OVER. IF FUEL COMES OUT OF YOUR LINES THAN THE FUEL PUMP IS GOOD. THAN I WOULD CHECK YOUR CRANK SEALS FOR LEAKING
Dec 24, 2010 | Polaris New Genuine Polaris Snowmobile...
1981 550 suzuki one cyclinder is dead has spark and fuel and bike runs but start extremly hard seems cold blooded
Check compression of cylinders, all should be close the same. Swap spark plugs and check if problem cylinder moved. If bike sits for long periods of time then most likely it will be a plugged carburetor.
May 20, 2010 | 1984 Suzuki Gs 550 L
Polaris 2005 Classic 550 Logo
375 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
