Question about NEC Versa Computers & Internet
Turn off touch pad nec versa p7200 - Versa NEC Computers & Internet
3 Suggested Answers
SOURCE: NEC Versa VY22X/RX-L TOUCH-PAD FAILURE
perpy,, this is brian ...the answer to your prob is to go to your nearest technician ,,or if your not afraid to open ur laptop,,just clean it,,maybe it is not clean or it may have a thick dust...just try it bro
Posted on Jan 15, 2009
  • 942 Answers
SOURCE: i need a nec versa p7200 panel cover that turns
Hi...
try to find it in this site that i can provide, click the link below
www.ebay.com
Goodluck!!!
Regards
PCmania
Posted on Jul 02, 2009
Turns on put dont start just turn back on
Are we talking about the NEC Versa P7200?
Let me see if I have this straight..........
Turns on, just shows a blue screen, then shuts off.
That about it?
Virus?
I would be more inclined to say the laptop is dirty inside.
Air is used to cool the hardware components inside a computer.
Basic cooling system consists of a Cooling Tube, Heatsink, and Fan Assembly.
Cooling Tube:
Slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
Has a metal plate, or plates; attached to one end.
Heatsink:
Small strip of metal that has Tall, Thin, fins protruding from it.
This is mounted to the opposite end of the Cooling Tube, from the metal plate/s.
Fan Assembly:
Small multi-bladed fan sitting in a D-shaped shroud.
Let's look at an example, (Not for yours),
http://www.ebay.com.au/itm/NEW-NEC-Versa-S900-Fan-Heatsink-GC054009VH-8-V1-B492-M-/270295120853?pt=US_CPU_Fans_Heatsinks&hash=item3eeed83bd5
Two views are shown.
The view on the Right is a Top View.
Let's refer to it, with references also to the other view. The Bottom view.
At the bottom you see a rectangular shaped piece of metal, with 4 holes in it. One in each corner.
For this particular model it sits just on the Processor.
Heat is absorbed by that metal plate, and the curved copper Cooling Tube absorbs heat from the metal plate.
The Cooling Tube then transfers the heat, to the rectangular shaped finned Heatsink.
The Heatsink absorbs the heat, then radiates it away with it's Tall, Thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
If the fins of the Heatsink are blocked off with 'Gunk', and also the fan blades; the laptop overheats.
['Gunk' = Dirt, dust, hair, lint, food crumbs,....you name it ]
This is an example of a laptop that is dirty inside,
http://www.youtube.com/watch?v=AkAeE5I5E_A
You can see this model has 3 Cooling Tubes, and metal plates; plus 3 Heatsinks.
(0:46)
When a Processor overheats it turns off. (BIOS turns it off)
This is a fail-safe feature that is built-in.
Keeps the Processor from burning up.
Also the Thermal Paste dries up from overheating.
And Thermal Pad.
(A Thermal Pad is a material that is impregnated with Thermal Paste)
Thermal Paste is used on top of the Processor, most of the time.
Other times a Thermal Pad is used instead.
A Thermal Pad is generally used on a graphics chipset.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 16, 2013 | NEC Versa Computers & Internet
Can u guys help me?? i got a problem to take out the HDD.. my laptop model is NEC VERSA S3301.. i don't know how to open it!!
HDD is on the front side with the mouse sensor.if touch pad is most left then hdd is on right side and if touch pad is right most then hdd will be on left side.
you can find hdd by open the keyboard side.there will be two or four screw on th backside or bottom of laptop.open these screws then pull touch pad carefully.dont force it may be you open wrong screws rather then correct screws.
hdd always on the side of touch pad its now on you how to open it.
Jun 28, 2011 | NEC Versa SXi Notebook
Touch pad is not working?
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
May 25, 2011 | NEC Versa FX Notebook
Cant find sound driver for nec versa p7200.. hep?
Hi!
You can try this site:
http://driverbyte.com/nec-versa-p7200-sound-driver_freedownload/
Feb 21, 2010 | NEC (158-026228-0) Sound Card
My laptop nec versa stopped to work suddenly. I
A questions are to be asked here. Does the laptop work when connected to AC power supply? If yes does the battery charge when connected to AC? If yes does this turning off happen when running on battery too? Please answer these questions so that I can help you with the diagnosis.
Regards,
Sai.
Nov 21, 2009 | NEC Versa VX Notebook
Touch pad isn't responding to double taps
It is probably damaged. Take it to a service center or call Tech support.
Sep 18, 2009 | Computers & Internet
I need a nec versa p7200 panel cover that turns laptop on . where do i get one ?
Hi...
www.ebay.com
Goodluck!!!
Regards
PCmania
Jul 02, 2009 | NEC Computers & Internet
Jul 09, 2008 | NEC Versa FX Notebook
Nec versa litepad
Here Try this website they were the cheapest here . Hope this is what you are looking for. should be the right one thanks for looking
http://www.pchub.com/uph/catf/SearchItem.aspx?ft=nec+versa+board&gclid=CPDF3O-VrpACFSBMGgodTANs8g
Dec 16, 2007 | NEC VL-PAD-933 Tablet PC
Computers & Internet Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
