Question about Samsung Stove / Oven / Range Oven Thermistor Sensor - DG32-00002B
Induction elements turning off on their own
I have the ne597n0pbsr. The right side elements will bring a pot to boil then shut off. Is as if it defaults to the left rear element which is the flex element. The panel will show a FL and needs a few minutes before it can be turned off manually. This same rear flex element will bring a pot to boil and continue to work. If I try to cook on any other element they will all shut off, including the left rear which was heating correctly. What part needs to be replaced, Thanks.
  • 185 Answers
SOURCE: no heat for microwave
its probally the magnatron
Posted on Jun 28, 2008
localwonder
  • 6784 Answers
SOURCE: Does not heat. Heating element was replaced and
Check the following to address this issue.
1. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2. Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If all checks out OK above, replace the main control board.
Posted on Jun 17, 2009
  • 56 Answers
SOURCE: my dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
Posted on Jul 02, 2009
jerryg50
  • 1673 Answers
SOURCE: when i turn my tv on 3/4 of the right side of the
The problem is most likely in the image processor area, or the backplane circuitry on the screen itself.
The service rep would be equipped to properly service your set. You should call LG to find out who in your area is able to service your set.
If the set is out of warranty it could be fairly expensive to service.
Jerry G.
Posted on Dec 16, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have a samsung DV337AEG/XAA Electric Dryer which
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Posted on Mar 25, 2010
Can you put a Greek coffee maker on a glass top new coker
There are essentially two types of Coffee Maker, one where the water is heated by an immersion element (where the water is heated by electricity), and a Boiling Water Coffee maker, where you heat the pot on a stove top element either by gas or electric heat.
(If you hve one of the electric immersion ones, don't do what a famous comedy showed and place the coffee pot on the HOT SURFACE of the cooker.
While the first pot of coffee might get warm, the idea is to heat the water from the inside, then have the coffee brewed by the machine after.
Is there a MODEL or NAME on the BOTTOM of the maker?
Google or search for these things first and get back to this board if that does not help.
If I understand your question (sort of) , are you asking if a Metal pot can be placed on the top of an INDUCTION type cooktop, where the special rings Induce a current of electricity into the bottom of the fry-pan or Stock-type pot to boil water or fry items in oils.
I do not know if there is any special method used in Greece to make coffee. Please provide details, if you were not having a 'glass' cooktop.
After some research, a 'Greek' coffee maker or 'Bricki', is a stainless steel or copper pot used to boil the water and grinds together without any extra filtering.
So, the Original Poster needs to determine what the pot is made from (The type of metal), and the other part is what type of cooker element is underneath the 'glass' part of the stove.
The Test is if you turn on the element, and watch it, does it glow red underneath or not?
If it glows red, then the heating elements are embedded into the glass and the stove functions similar to a regular electric range.
If the 'glass' portion is black and does not glow red without a pot on the top of it, then it is an INDUCTION element, and the Inductor NEEDS a metal pot on top to induce a magnetic field to make the bottom of the pot warm up.
Based on the Size of the Pots shown in pictures, it may be too small to function in your particular cooker. A model of the cooker would help. The label is usually on the door frame to the oven or a logo or name near the contol knobs.
Sep 06, 2017 | Coffee Makers & Espresso Machines
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
How do I fix an Electrolux induction range element that is not at full power?
Thank you for your post, friend!
I see that you are having difficulty with your induction range element on your Electrolux range. From the information you have provided it is taking longer for items to heat up on that burner. You may need to have that burner replaced and I would recommend having a professional technician come out to perform any repairs. This is not a simple DIY job it may require a possible disassembly of your range. I hope this information has been helpful. -Matt
Feb 18, 2015 | Electrolux EW30IS65JS - 30"Electric...
New rangemaster prof.fx90 induction cooker but hob not working. - comes on if a ring is on if you touch the hob but no other lights come on + it won't heat up.
Induction stovetops wont heat until a metal pot is put on top of the element. They work through electromagnetism. These tops wont work with glass or aluminium pots. They have to be steel.
Nov 28, 2014 | Rangemaster Kitchen Ranges
Whenever I cook pasta the water boils over and causes a terrible mess. How can I stop this happening?
The most common cause of water boiling over when you cook pasta is if you cook it with the lid on the pot. Don't cover pasta fully with a lid. Either cook it uncovered or if you are in a hurry to cook it quicker, just partially cover the pot.
Also make sure you don't overfill the pan with water as this is another cause of overboiling.
Jan 10, 2013 | Cooking
One plate in Bellini induction cooktop continues to flash with a pot on it, yet the pot works on the other 3 plates. How do I fix?
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
Feb 13, 2012 | General Cooktops
I have acquired a rival rice cooker 4310 and it won't heat up. It appears to be the power cord as it doesn't show any power flow with the multimeter on the heating element or the resistor. no...
There is a heat sensitive switch attached to the inner pot. It is very small, it turns the heat off when the pot reaches boiling temp. If it is open, replace it. They come in different temps, so get the right one. This one is supposed to open at 212 degrees, f. You will find a similar one in a Mr. Coffee, it switches the pot from boil to keep.
Sep 24, 2011 | Rival RC61 6-Cup Rice Cooker
On the dial there is off, low, high and auto. What does the auto do? If I select auto is there a timer on it that shuts the pot down after a time? Is fo what is the time.
There is no timer -- with the dial set to auto, a thermostat opens and closes turning the heating element(s) on and off to keep the pot at a fairly constant temperature. The high setting can continually boil the contents, and can burn the food if not stirred. The low setting is for keeping contents warm.
I'd use "auto", if the pot is not going to be monitored.
Charlie
Mar 27, 2011 | West Bend Crock Pots & Slow Cookers
Water boiled over on the Right rear induction side. Stove shut off. Now the Right rear burner doesn't work and flashes and "F" when I set any temperature. Stove thinks I have the wrong type of...
Generally there is a number after the F. It sounds like some liquid got into the electrical, sometimes if you wait about a week for it to dry it will work. If not, you would need to call a service tech
always unplug electricity before attempting to repair on any electrical appliance
Sep 14, 2017 | Electrolux 30" Built-In Electric Cooktop -...
Samsung Stove / Oven / Range Oven Thermistor Sensor - DG32-00002B Logo
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
