Question about Sub-Zero 632 / S
Interior dividing wall between freezer and refrigerator gets hot
The interior dividing wall between the freezer and the refrigerator gets very warm. Temperature doesn't seem to be affected
3 Suggested Answers
ailia
  • 175 Answers
SOURCE: Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Posted on Jul 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: the divider between the freezer
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Here's how to test the fan.
Posted on Jul 10, 2011
I have a frigidaire side by side refridgerator / freezer. Currently my freezer is about 34 to 40 degrees. The dividing wall between the ref. and freezer is warm to hot depending on when you check it. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Frigidaire FRS26H5AS Side by Side...
Interior wall of unit gets extremely hot
If you are talking about the wall that runs between the freezer and the fridge where the door gaskets actually touch. The answer is no. It should be warm though.
What can cause this is the fan that is located at the rear not operating or dirty coils under there. Check the fan it should be operating when the unit is in the cool cycle, if it is not then it will need to be replaced. And clean the coils. This will help.
May 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Center Divider VERY hot...
The center divider gets very hot , when the fan motor that cools the compressor stops or the coils at the front bottom , gets clogged with dust , lint , pet hair , etc . Check the coils to make sure they are clean . Next , pull the refrig out from the wall , and remove the bottom panel . Check that the fan is working and that nothing is blocking the fan blade , cooling the compressor and coils .
Oct 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Ice melts, then refreezes. Rubber Is HOT
Pull the refrig out , and remove the back panel . Is the fan that cools the compressor working ? Is the coil roll clean ? If the fan is not working , then the problem is probably the main control board . Behind the 8"X10" panel , above the compressor area . Remove the cover , and look for a burnt resistor , just to be safe . If this fan does not work , then the coils and the refrigerant line running between the doors , will get very hot .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The dividing wall between the freezer compartment and refrigerator compartmant is very hot to the touch , use to be warm now almost to hot to touch. mod. #106.56539400
the condensor fan by the compressor is not running. this fan cools the compressor and condensor coils. if it does not run then the mullion (center between frzr and refrigerator side) gets very hot
Jun 24, 2009 | Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hot
check to see if the fan at the compressor is running
Jun 17, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Sub-Zero 632 / S Logo
14 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
