Question about LG V271 DVD Player/VCR
Cannot program tv channels to LGv271
Have removed set top box and now want to attach a tv to LGv271
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have an LG RH397D/RH399D
Hi.
Below the step-by-step procedure. When it asks Choose a Broadcasting Type, set it to ALL (digital TV and analogue). Ensure that the antenna is well connected to the socket at the back of the unit. ensure that the antenna is a digital TV aerial.
If scan goes on but there are no channel, then problem is aerial. In that case repace antenna or use a signal booster for digital TV.
Here instructions:
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 25, 2010
walesarumi
  • 6993 Answers
SOURCE: 32LF15R I cannot tune in
yes the TV needs to be connected to set up box or an antenna before it can tune up TV channels?
If your TV is connected to a cable box, figure out what AV input it is connected to. Then go to your TV remote and switch to that input.
If your TV is connected to an antenna, then go to the same remote and switch to the TV input and scan for channels.
If you have done all of that and are still having problems, please provide a little more information in your next post and I'll try and help you resolve the issue.
Regards.
Posted on Sep 16, 2011
How to program channels
go into settings and then rescan for channels
May 07, 2015 | Televison & Video
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Just need to know hoiw to tune set top box to tv
I'll assume that you mean "CONNECT set top box to TV". Look at both devices for the options of physical connection. If both have an HDMI connection, choose that first. If HDMI is not an option, then see if component connection (5 RCA connectors: RGB+RW) is available. If both are not options, then see if AV is an option (3 RCA connectors: Y+RW). If you have a real dinosaur, then go with Coax and set the TV to channel 3 or 4. Now that the TV is connected to the set top box using the best available connection, program the set top box as required by that particular box. From now on, you'll only change channels with the set top box.
Jul 19, 2011 | Televison & Video
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
No welcome window, set up menu from Insignia converter box.
Make sure your TV is tuned to channel 3. If you don't see a picture from the converter box change the TV to channel 4 and check for the converter box output. If you continue to have a problem with the installation, the FCC has a hotline to help solve setup problems. They can even arrange for someone to come help with the setup at no charge to you. Call 1-888-CALL-FCC.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV Setup
Are you using a top of set box? If not make sure the set is set for cable then do a auto program/ channel search. The tv most likely is set for ANTENNA .. If you have a top of set box it could be the problem..
Apr 21, 2008 | Insignia 37" LCD Flat-Panel HDTV
LG V271 DVD Player/VCR Logo
14 people viewed this question
Computer Repairing
Computer Repairing
