Question about Lanzar SNV695N 6.95" Dd - Nav W /bluetooth
Have a lanzar snv695n and having problems with the ASwc-1 with the steering wheel setup. I have a 2004 kia sorento
My car is leaking power steering how to fix it?
With hydraulic power steering.
You may have a pressure hose and return hose, if problem with hose, you replace it.
I can't rule out a problem with rack&pinion?
Your steering shaft probably attaches to rack&pinion assembly.
May 03, 2016 | 2004 Kia Sorento
I have lanzar snv695n in application they ask about factory pass code in manual you don;t find where i may get it
You may buy one from the makers dealer but it will cost you, about £25.00 in the UK.
Feb 01, 2015 | Cars & Trucks
Kia sorento 2005 ignition switch how to replace?
steering wheel needs to come off and switch must be in accessory position to remove and install.mounting clip is under steering wheel.
Mar 19, 2014 | 2005 Kia Sorento
What is aswc harness in the gmos-lan-02 harness
Axxess ASWC Steering wheel control
ASWC = Axxess Steering Wheel Control, it's the additional wire harness you need in case you have controls for your radio / sound system on the steering wheel.
Apr 10, 2012 | GM Carts Axxess Gmos-lan-02 Gm Factory...
Power steering hose on 2004 kia sorrento leak
You have to repair it, or if it is loose at the connections, then tighten it. Otherwise if you do not repair it, then your powersterring will not work, sterring wheels will become stiff when driving.
Jan 10, 2011 | 2004 Kia Sorento
2004 kia sorento wont shift past 25 mph why?
I believe your transmision gone bad and needs replacment or rebuild, Unless this a 4wd modelSsorento, if so, you have your 4wd turn on and on the low 4wd side in Lx models if this is a 4wd sorento ex, equipped with the auto/low 4wd knob. You might have the knob, or accidently shift the knob to the (low 4x4) position, and if you do, then the car is set only to run on the first gear for max tranction and to prevent your differential from overheating. This knob is located on your left side of the steering wheel, and if turned to the 4wd postion, it needs to be in the auto or 2wd poistion.
Jan 06, 2011 | 2004 Kia Sorento
2004 kia sorento, horn not working. It works when the remote horn button is pushed.
Check the wiring in the steering wheel. It may of came undone.
Nov 30, 2010 | 2004 Kia Sorento
I put a new battery in my 2005 kia sorento and now the air bag light comes on and stays on once i have started the car
When the airbag light (SRS) is on or blinks it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called the clock spring contact, a coiled up ribbon electrical contact that turns with the steering wheel while maintaining a mechanical connection to the airgag mounted on the steering wheel, to replace this part you must disarm the airbag system and remove the steering wheel, this requires a special steering wheel puller tool and that you disarm the airbag system before you start the work, to do this disconnect the battery negative cable for 1/2 hour prior.
Apr 25, 2010 | 2005 Kia Sorento
Steering becomes difficult sporadically
this could be one of 3 problems .1 are you low on fluid ,2 bad power steering pump.3 bad rack and pinion .
Jun 18, 2009 | 2004 Kia Sorento
Lanzar SNV695N 6.95" Dd - Nav W /bluetooth Logo
Top Lanzar Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Lanzar Clothing Accessory Expert? Answer questions, earn points and help others
