Question about Toshiba e-Studio 161 Copier Copier
Line is coming in copy ,while taking photocopy line is coming on the photocopy page
If happens only when using doc feeder it is a spot on small glass on left below doc feeder. clean it well
Posted on Feb 10, 2014
Copy problems with xerox fx docuprint c3290
Hi you can have a few problems. 1: try cleaning the glass on the scanner. 2. If you have auto document feeder there may be paper or dirt on the lens that the paper passes over. Clean the long lens. 3 if you clean the glass and lens and still have the problem you will most likely need to have it serviced as there may be paper stuck in the drums that the paper passes through. Paper follows a different path when copied versus a straight print. Try to see what path the copy paper is taking and clean it as best as possible. Last trick is to take out toner cartridges and wipe them clean. Shake them forward to back and reinsert. You may have a worn out roller and if this is the case it is usually cheaper to just buy a new printer.
Nov 01, 2012 | Xerox Computers & Internet
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
I have a problem with our HP3030 in that when I try to photocopy using the document feeder, the pages all come out with a double black line running down the centre of each page. The same problem comes with...
You're right. There is probably debris on the glass where the paper passes through. It's a common problem. You'll have to raise up the scanner so that you can see the glass. Then clean it off and you're back on business.
Apr 30, 2009 | HP LaserJet 3030 All-In-One Printer
Photocopies with black lines from top to bottom.
Try check your paper, see whether loaded properly or not.
If yes, probably u need to adjusting your casette
Feb 17, 2009 | Toshiba 1360 Black and White Copier
Canon photocopier 1600 Cleaning Blade not cleaning properly
Perhaps the pblm is not in "the drum unit"... check the mirrors may be are dirty.
Jan 12, 2009 | Office Equipment & Supplies
Black photocopiers
Did you try to make sure the primary charge corona unit is it all the way and locked down. Take it out and look to see if the wires are not broken. If the copier has 30k on it, I need to know if the OPC drum has ever been replaced? They are rated for only 10 to 15k print outs. If you really want to know for each page that comes out it has to make 4 copies on the same drum for one out put page. You are not getting a error code? Most of the time if the drum was old or bad you would get a E061. How about the dose the scannig lamp come on? You got me thinking now.... It has been years scine I worked on one.... I'm don't done yet..
Dec 17, 2008 | Office Equipment & Supplies
Canon IR7105 Photocopier
Hello tophams,
I wish I had a magic wand to help you...but the answer is YES! You can fully control the priorities of how the 7105 handles printing/copying/scannng requests. I truly understand your dilemma, it is merely a matter of how the device has been configured. You can program the device to give priority to copies, which will cause print jobs to wait in the que until your copies are done. You can have the print jobs sent to a "mailbox" so that the person requesting a print job will have to walk up to the device and "summon" their print job. There are so many ways to help you with this. You will have to get "THE BOOK" out. I can't type all of the options available to you.
Jul 03, 2008 | Canon NP 6551 Black and White Copier
Toshiba e-Studio 161 Copier Copier Logo
41 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
