Question about Samsung DLP HL-P5663W 56" TV
50 " DLP makes a high pitch squilling sound and shuts off several times
The set makes a high pitch squealing sound while on, sound is coming from the fan area. has been doing this for several months, now tv shuts off and when you turn it on it makes a frying sound and you can see a dim light on the screen at the 6 o'clock position while it is making the frying sound. Sometimes it comes back on others it comes on then shuts right back down. Now the picture is showing dim. The bulb has just been replaced last year.
    Top Expert:
  • Samsung Master
  • 74,232 Answers
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 10, 2014
  • 100 Answers
SOURCE: SAmsung DLP Model # HZN617WX/XAA
It sounds like the ballast that powers your lamp is bad. What are the indicator lights on the front of the tv doing?
Posted on Oct 31, 2007
rey jr
  • 149 Answers
SOURCE: Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Posted on Jan 01, 2008
SOURCE: it's a Samsung SlimFit HDTV TX-T2782
I was told that it might be a flyback transformer issue. Hope that helps, I'm still looking into getting mine fixed.
Posted on Jan 05, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Posted on Feb 13, 2008
SOURCE: dlp tv will not "fire up"
It doesn't have a flyback or an HOT genius. It's a DLP.
Posted on May 24, 2008
Samsung HLS-6167W shuts off every few minutes. I replaced the lamp 3x and recently the lamp ballast and #2 fan. Problem continues, so should I look at the power supply board or the color wheel?
if the sounds a high pitch squeal !! I had an ole tv that did that when u watched it , finally one day the dang power supply up and gave out !! so that must be what the noise was coming from all that time !!!
Dec 20, 2016 | Samsung Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Engine squeal when starting
Hi JoAnne,sounds like your belt is squilling,here's a link to the belt adjustment or removal.
Dec 22, 2012 | 2005 Kia Sportage
Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
High pitch squill
his water pump froze. it blew the freeze plug and then the pulley locked up, it needs to be replaced
Jan 18, 2009 | 1994 Eagle Talon
High pitched squeal in engine
loose fan belt?
Put the car in neutral, set the parking brake, open the hood, get someone to listen/see where the sound is coming from, as you press on the accelerator.
Dec 26, 2008 | 2000 Dodge Neon
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
GE D52gw12
The set is shutting down to prevent further damage. There is a problem with the high voltage circuit. The most common failure part is the horizontal output transistor. Figure on $20 or so for parts plus the local labor rate to get the total repair cost.
Dan
May 30, 2008 | GE Televison & Video
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
