Question about Juki Sewing Machines
Lower feed dogs
I have a pre-owned Juki 5550-N and would like to know how to lower the feed dogs on this sewing machine
    Scholar:
  • Juki Expert
  • 176 Answers
Hi there
please see next photo, it\'s for how to adjust height of feed dog.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
Posted on Feb 13, 2014
  • Abigail Tobler
    Abigail Tobler Feb 13, 2014
    Thank you so much I will give it a try
SewTechWayne
  • 186 Answers
SOURCE: Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Posted on Jan 30, 2009
RickE1
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
Zenqi
  • 208 Answers
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Posted on Jun 17, 2009
I lowered the feed dogs on my Juki TL-2010Q to free motion quilt and they won't raise. I cleaned under the throat plate. Help?
Have you tried sewing with it since you "raised" the feed dogs? The feed dogs will not raise until you begin to stitch.
Mar 12, 2017 | Juki Sewing Machines
Feed dogs won't raise on tl-2010q after lowering them
Hello Lisa Girodat
Referring to the manual, pg 28, make sure that the feed dog position lever has been activated. The feed dogs should come up after the first full stitch.
If you do not have a manual, you can download it for free here: https://www.juki.co.jp/household_en/pism/img/tl2010q/download/Inst_2010Qi.pdf
Please let me know how this works out for you.
Happy Stitching
Sewingirl/
Mar 12, 2017 | Sewing Machines
How do i lower the feed dog for free motion sewing??
Oooh, consult your owner's manual. Frequently, industrial machines are limited in their capabilities so your machine may not have the feed dog lowering ability. Some other domestic machines without the capability can use a plate to cover the feed dogs while free motion quilting, but that probably wouldn't be a good thing to try if your machine is not made for sewing without the feed dogs in use.
Nov 05, 2015 | Juki DDL-5550 Industrial Straight Stitch...
Black oil marks on fabric when sewing
theres a screw that controls the amount of oil that reaches the upper head. tilt machine back and look for screw with head that has an arrow indicating + or - tighten in minus direction. maybe u need a new needle bar guide too.
Mar 20, 2014 | Juki DDL-5550 Industrial Straight Stitch...
I own the singer advance 7442 and want to lower the feed dogs in order to use a quilting foot to machine quilt.However I don't have my manual and I need to know how to lower my feed dogs.Can you help me...
The 7442 does not have feed dogs which can be dropped. You need to use the "Darning Plate" which came with the accessories.
http://www.singerco.com/accessories/manuals.html
Nov 01, 2010 | Singer 7442 Mechanical Sewing Machine
I just got this machine new and feed dog
It may just be stuck from being in storage and unused.
Try oiling the machine as per the manual, lowering the feed, and running the machine. The movement of the linkages may free things up. Another thing you can try is applying heat from the underside (open the bobbin access door and blow the heat in) as the heat will allow the oil to seep in better...then run the machine some more.
May 14, 2010 | Juki TL-98Q
I bought a second hand Juki industrial machine , model DDL 5550-7, but struggle to get the tension of the stitches right. where do you set the lower stitches tension
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Jul 01, 2009 | Juki MO-644D Mechanical Sewing Machine
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
76 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
