Question about LG Optimus LTE LU6200 Smartphone - Unlocked White
Data connection is blocked - LG Optimus LTE LU6200 Smartphone - Unlocked White
I also can hear that fuel pump winding...how does the relays in the glove compartment work...will they affect a cold start?
Not if the fuel pump is operating. It is more likely the Ecu is not getting the temperature data from the engine block temp sensor. There are usually two temperature sensors on the block. One provides temp to the dashboard temperature guage. The second, the most critical for cold start, provides temp data to the Ecu which determines the cold start program. If you are a DIY you need a repair manual, if not now later. Auto repair stores may have, your library may, or filepeep.com if they have it, or
manualslib.com. (Make model year) It will show where the block temp sensor for the Ecu is. It may need to be replaced. However I found on my 20 yr old auto that corrosion had compromised the data and caused a very rough, difficult start. I cleaned and scraped the connecting parts to bright metal. Reset error codes and Instant start, just like brand new. So double check for clean connections first. You may find it very difficult to access the connections. Thus the need for a repair manual.
Mar 26, 2015 | Cars & Trucks
Tip
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
on Sep 14, 2015 | Apple iPad Tablets & eReaders
Tip
Nokia contact service Tricks
Nokia dct4 contact service hardware or software easy to find<br /> <br /> <br /> NOKIA DCT4 CONTACT SERVICE HARDWARE OR SOFTWARE EASY TO FIND WITH UFS+HWK<br /> <br /> <br /> 1)CONNECT UFS+HWK<br /> 2)SELECT DCT4 TAB<br /> 3)USE INFO BUTTON(SOME TIMES PHONE NOT ENTER LOCAL MODE JUST LONG PRESS POWER BUTTON<br /> 4)CHECK INFO DETAILS<br /> <br /> <br /> <br /> 5)SL DATA CORRUPTED(MEANS SIMLOCK ENABLED)<br /> 6)JUST UNLOCK PHONE<br /> <br /> <br /> <br /> SEE SECOND PICTURE INFO DETAILS 100%DONE.BUT PHONE STILL SHOW CONTACT SERVICE<br /> 7)CONNECT SET<br /> 8)RUN SELF TEST<br /> <br /> <br /> <br /> SEE THIS SELF TEST DEIALS<br /> EAR _CLK_LOOP TEST----------NO SIGNAL<br /> RF CHIP ID TEST---------------FAILED<br /> THIS CONTCAT SERVICE HARDWARE PROBLEM<br /> HARDWARE CHANCE<br /> 60%UPP<br /> 30%UEM<br /> 10%OTHERS LIKE BSI ETC...........<br /> <br /> <br /> <br /> SEE ANOTHER SELF TEST DETAILS<br /> LCD TEST-----------FAILED<br /> RESONS LCD MISSMATCHED<br /> JUST CHANGE DISPLAY NO NEED TO FLASH&UNLOCK ETC.............<br /><br />or alternatively....<br /><br /><br /><br /> <b>SX4: SX4 <span>Smart Card</span>, is a tool or method which is developed by Nokia to<br /> write some data protection for a specific area in EEPROM is useful for<br /> preventing modification of the data.<br /> </b><br /> <br /> When SX4 PROCESS is Required ?<br /> <br /> <b>In the case of a loss (data corrupt) data charging (not charging), data<br /> network (no network). Dll.RF calibration calibration-charging.<br /> So, all these problems caused by mistakes in the process of flashing or after<br /> write RPL or erase process is done in a certain area <br /> </b><br /> <b><br /> <br /> <span>HOW DO I</span> KNOW THAT MY PHONE PROCESS SX4 needs to be done?</b><br /> <br /> <b>When the phone appears CONTACT SERVICE, CONTACT retailers, NOT<br /> charging after flashing, no network, etc. When the SELF TEST is done by<br /> using the box like JAF repair, etc. will be obtained is the result of failed "ST_SECURITY_TEST Failed"<br /> <br /> <b>How do I make a SX4?</b><br /> .</b><br /> <br /> <b>Plug the phone in the repair box (JAF, MTBOX, MXKEY, etc.)<br /> Write pm area with 309 results read from the normal mobile phone or can<br /> also write FULL PM area without 308 (<span>SIMLOCK</span> area). </b><br /> <br /> <br /> <b>What to do sx4 without internet connection?</b><br /> <br /> <br /> sure <span>Certificate</span> damaged area musti made first with the FLASH erase, or<br /> write RPL blank<br /> Reset NPC (when using mxkey)<br /> What is a Certificate Area?<br /> Press info on the box like JAF flasher, etc. and see the results LOG ...<br /> This is an example of the correct Certificate<br /> Default SN type:<br /> <br /> Code:<br /> <br /> IMEI plain: 351862xxxxxxxxxx<br /> IMEI spare to net: 3A 15 68 02 01 23 60 03<br /> IMEI SV to net: 33 15 68 02 01 23 60 03 F6<br /> LOCK STATUS:<br /> Config KEY: 0000000000000000<br /> Provider KEY: 2440700000000000<br /> Provider: AT &T; U.S.A. (3650)<br /> <span>Key Code</span> count: 0, FBUS Code count: 0<br /> Block 1:Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> This is an example Certificate of damaged<br /> <br /> Default SN type:<br /> <br /> Code:<br /> IMEI plain: 123456765321?<br /> LOCK STATUS:<br /> Config KEY: fffffffffffffffffffffff<br /> Provider KEY: fffffffffffffffffffff<br /> Provider: Unknown<br /> Key Code count: 0, FBUS Code count: 0<br /> <br /> Block 1: Lock 1: CLOSED<br /><img src="moz-screenshot-2.png" /><br /><br /><img src="moz-screenshot.png" /><img src="moz-screenshot-1.png" />
on Apr 26, 2011 | Cell Phones
How to I put data onto my tablet when I don't have wifi
You don't need internet, to put data on a tablet (or on a computer) entering data, is typing a note, or making a picture. Then save it. That is how data becomes data. But if you want to receive data from the internet, most tablets need a wireless connection. And unless you have a hotspot close to home, the only way would be to visit a Starbucks or McDonald, where they offer free WiFi, while you are consuming there.
More and more firms offer free WiFi, when you are visiting them.
If you want WIFi at home, you first need an internet connection. If you already have an internet connection for a computer, you could buy a wireless router and connect it to the same router you already use for the computer. If you don't have an internet connection, you should get one. Most providers, now offer routers with WiFi and cable connection.
Sometimes if you have a smart phone, with internet connection, you can setup our phone as a hotspot for your tablet. But some providers try to block that.
And soem tablets do have a possibility (they cost more) to insert a sim card. For those you goto a provider and arrange a data plan for the tablet.
I hope this helps. Make sure you don't have a WiFi router, before you buy one.
Nov 19, 2014 | Tablets & eReaders
Can't play Words with Friends. Help.
Where are you trying to play it at? Assuming you are using a wifi connection, wherever you are getting wifi access at has blocked it. Try turning wifi off and using your data instead.
Feb 17, 2013 | Compaq Computers & Internet
We have a veriable length (VB) record EBCDIC file on UNIX and we're trying to send to the MF. The BDW and RDW settings are in place, but the MF doesn't seem to understand, so it cascades the data. Any...
Use 'TYPE E' and 'MODE B' file-transfer options to transfer the file, block-for-block, without converting from ASCII to EBCDIC, and without re-blocking the records.
Mar 15, 2011 | Computers & Internet
When i connect my hard drive to my laptop it does not show how much data on my hard drive and it has asked me to format my hard drive
Is it a "brand-new" external storage device? If so, then it must be "initialized" before being used for the first time.
If you have been using it, then the "Table-Of-Contents" on the disk-drive has become corrupted.
Since Windows does not recognize the data as being a valid T-O-C, Windows is asking your permission to write a new, valid, empty, T-O-C onto the disk-drive.
Perhaps, all the other blocks of data existing on the disk-drive are still valid.
Look online for a "file recovery" or "file scavenger" program,
which reads through the disk-drive, block-by-block, trying to "stitch" the blocks together,
to reconstruct your files.
Nov 04, 2010 | Maxtor (6L250R0) 250 GB Hard Drive
Facebook problem
Nothing to worry about. This usually happens when either the connection is lost or no data is being sent or received via internet. make sure that your internet connection is working perfectly!
Nov 07, 2009 | Facebook Social Network
Usb
please click follow:
http://www.pctechguide.com/tutorials/MBoard_USB.htm
acording the table and picture you can make easy to correct your USB connection.
hope help you fix it, any question send any time please!
please take a rating let me know how much helped you, thanks!
May 17, 2009 | MSI 865PE Neo2-PFS Motherboard
Wi-fi
You probably called their customer support or billing, which know nothing about technical stuff.
Wi-fi is completely independent from the cellular network, so it will not charge you anything. Wi-fi just connects to a wireless router, like the one in your home, if you have one. In other words it connects to the internet via someones home/office internet connection. I have a touch diamond and dont have a data plan, and only use wifi, works great..BUT:
If you do not have a data plan (pay as you go data) with Bell, IMMEDIATELY get a 'data block' on your phone, at first they might say oh it will not let you use some functions, etc, put insist, persist, and use force if neccesary as they dont like giving you a data block..It costs about $50 per mb if you use the pay per use internet! I think that was the 1X, but im not sure, its ridiculously high!
Mar 07, 2009 | HTC Touch Pro Smartphone
LG Optimus LTE LU6200 Smartphone - Unlocked White Logo
27 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
