Question about Electrolux 154685101 Frigidaire Dishwasher Splash Shield Kit 5 154685101
Tub corner gasket
How do I install this part?
    New Friend:
    Problem Solver:
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
Dec 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher leaking
Hello Colleen Starr - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, or gasket not sealing properly. I would strongly suggest contacting a professional to move forward accurately.
Nov 18, 2012 | Frigidaire Dishwashers
Frigidaire dishwasher (FDB1100RHC2) is leaking from bottom right corner and it appears there are small hairline cracks on the plastic tub. Is there a way to repair them?
Hello - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, from what you have described it sounds like the springs or hinges may possibly be damaged, or gasket not sealing properly. I would strongly suggest contacting a professional to move forward accurately.
Oct 12, 2012 | Electrolux Frigidaire Professional Series...
My dishwasher is leaking out the front. It drips from the lower left hand corner. Any suggestions to what is causing the leak?
Either the tub gasket needs replacement (item 3) in this diagram. or the door base gasket needs replacement. Alternatively, the door vent seal could be leaking. Item 4 in this diagram.
Hope this helps.
Jan 10, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
We are ready to install the Duracraft Plastics Schedule 40 Foot Lok style bath drain and have a question on the foot lok drain gasket. Does the gasket install on the inside or outside of the bathtub and...
The gasket is installed on the outside of the tub. Use plumbers putty under the male end on the inside of the tub as it stays permanantly flexible and will not mildew like silicone caulking can. Do not silicone or use plumbers putty on the gasket. The gasket will seal nicely under pressure from the connections.
Aug 02, 2010 | Home
Top loader dumps water on floor from rt. front lower corner
The tub-to-pump hose is likely cracked, or one of the tub bolt gaskets has compressed enough to permit leaking from the front right support leg.
If the washer is very old, it is likely that there is an old-style pump installed, in which the pump gasket or shaft seal has failed.
Aug 31, 2009 | Maytag Washing Machines
Water leaking out of front door
Leaks coming from the front door are commonly caused by a worn tub gasket. The gasket is located around the perimeter of the tub opening when you opening the door. It can be easily replaced and is not that expensive. The part number is 8269110 and can be purchased at appliancepartspros.com for about $22.
Installation is easy. Just remove the old gasket by pulling it out of the groove in the tub opening. Clean the area to ensure it is free of any debris or build up from detergent or food. The new gasket should have a mark indicating the middle of the gasket. The mark should be on the side of the gasket that is to be inserted in the groove. Starting at the top of the tub opening, insert the center of the gasket first and carefully work the remaining gasket along the left and right sides, seating it in the groove. Make sure you do not twist it. The door may be a little more difficult to shut for a while until the gasket compresses and seats over time.
For future reference, here are some things that can wear these gaskets out.
1. The silverware tray rubbing against it as you roll the lower wash rack in and out of the tub. Knives and forks can catch on the gasket and tear it. Make sure you keep all utensils from the tub edge as much as possible to prevent them from scraping the gasket, or getting closed in the door.
2. Not cleaning the gasket periodicially. The gasket is the part of the dishwasher that water never reaches. If food gets on it and is allowed to dry, it can create irregular wear of the gasket facing, causing it not to seat properly against the door.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 26, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Electrolux 154685101 Frigidaire Dishwasher Splash Shield Kit 5 154685101 Logo
76 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
