Question about Grundfos Garden
Grundfos control unit CU 3 trips to dry running two minutes after its powered on
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Posted on Jan 03, 2010
  • 534 Answers
SOURCE: Heat / Cool unit runs approx 45 minutes then trips the breaker
Check the amperage of the breaker or change the breaker out completely with a new one. The tripping problem is that the breaker itself is heating up to the point that the bi-metal in the breaker (safety device) is throwing the breaker off. This could be the problem for you however, I would get an ampherage draw from the unit to insure that the breaker is the proper size for the unit. If you can find what kilowatt the unit is divide that number by the amount of current being supplied and that will give you the breaker size.
Good luck hope I helped you some
Dave
Posted on Jan 08, 2010
  • 8909 Answers
SOURCE: microwave runs about 3 to 4 minutes and shuts off
It sounds like the magnetron is not working properly and the temperature sensor is expecting temperature rise, it is not getting any and shuts down.
Hope that expalins it for you.
Posted on Dec 31, 2010
MOTORWIZJ
  • 1363 Answers
SOURCE: hot tub trips gfci
spa may be leaking water internally check to see all grounds are hooked up . or you might have a bad gfic
Posted on Sep 11, 2012
Where can I get repair parts for a Grundfos CU 200 solar controller?
Sorry we have no parts resources other than what you can find on the web.
Jun 23, 2016 | Grundfos Pumps Grundfos Smart Box...
Grundfos jetpaq pumps
Sounds like a broken connection or a link in the over temp circuit.
Or the controll is knackered.
I would say it is unlikley the motor has failed, I have stripped water related dead seized grundfoss units and freed them back up and they have outlasted an economy replacement unit.
I am assuming your unit is single phase, if it is there should be an internal OL reset.
I am not sure where exactly on your unit but if you open the control box it should be evident.
If it has tripped I would check the capacitor as over time they diminish in capacity which would lead to overloading or not start at all which would trip the OL very quickly.
Dec 01, 2013 | Plumbing
One of my 3 Grundfos UPS 15-58 FC pumps on my heating system has a slight rattle and is running very hot. The temperature drop across the pump is also much greater than that of the other supply side...
In most cases the impellers are what fail in these pumps. Generally speaking if a bearing is going out you won't have a heat difference you would have a pump that fails to run due to overheating of the thermal overload or the circuit breaker tripping. You can test the pressure to see if it's the same or close to the others 15% or more requires a replacement of the impeller.
Running these pumps without fluid will also quickly destroy impellers within 10 minutes. They require that fluid to stay cool.
Oct 13, 2013 | Grundfos Pumps UPS15-58FC
Grundfos runs intermittently and needs power cycle to get going again
What type of pressure switch or pump controller on pump? Could be capacitor check. with power on try spinning fan at rear if starts probably cap. Have it checked. Could be controller faulty.
Jan 27, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I have a problem with mq booster pump every 10 seconds kicks back and kicks on i am check the showers no leaks everything is ok please tell what can be a problem
Grundfos said the problem of on off every few seconds was air in the line. Then
later admitted it was the control unit. After replacing two units in 2 yrs I replaced
it with a standerd pump pressure switch.....Runs fine
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have had a Grundfos CME Booster pump installed for some ten months or so. We have a pump room alongside the 150,000 water tank. The inlet is suspended from a float within the water tank, and is about...
Hi Ray, did you ever solve your problem, I have a setup that sounds identical to yours and have the same problem, Grundfos are not been very helpful.
Oct 31, 2011 | Plumbing
Just bought a house and it has a grundfos timer/pump attached at the hot water tank. I have no hot water and the timer doesn't turn (as I've seen other timers do). Is it supposed to turn so that the...
Grundfos is a sealed unit and not a repairable item.
The timer dial should turn.
And pins located around dial control ON-OFF functions as timer dial rotates.
Does the receptacle have power?
If receptacle has power, and Grundfos is not working, then it is broken.
Grundfos manuals for UP series pumps do not show breakdown or parts list of any kind.
http://www.us.grundfos.com/web/download.nsf/Pages
Bigger question:
Why don't you have hot water?
Is water heater functioning?
Water heater is a separate appliance from Grundfos pump.
Grundfos pump circulates hot water from tank into the lines so there is no waiting for hot water ... but hot water heater should still make hot water.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Add a comment about water heater if that is also a problem.
You could have 2 problems, and water heater is main issue.
For do-it-yourself electric water heater repairs:
http://waterheatertimer.org/6DIY.html
Nov 20, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
Power Failure without tripping breaker
Sounds like an overheat code tripped due to obstruction in the exhaust. There is also a vent tube on the bottom of the dryer that could be loose.
Jul 27, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Garden Logo
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
