Question about Dynex 32 in. LCD Flat-Panel HDTV
Monitor won't connect to cpu
I plugged everything in right, I have the VGA cord and everything, but on the monitor it just says "unsupported mode". Please help! I payed a lot for this screen!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
OK,Hello. The screen resolution (probably the refresh rate also) is set higher then what your new monitor is designed for. boot your computer and hold down the F8 key this should bring up the Advanced Boot Options window. you will see a list . select Enable Low Resolution......using the up and down arrows -press enter or enter key. This usually works well for windows 7 and Vista. Now If Windows starts to your desktop you can now set your resolution and refresh rate properly- set the refresh rate at 60 Hz. Window should give you a Recommended Screen resolution rate. go ahead and use it. Good Luck
Posted on Feb 10, 2014
Today I received a faulty Monitor Dell E773c, the problem is that the Monitor get On and the power LED is Green and after remove VGA Cable from CPU it get Orange, But no Display (The Screen is Blank)
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
Sep 15, 2013 | Dell Computers & Internet
Monitor won't display. Everything is plugged in and power is on
Might not getting any signal from the source ,you will have to try your cpu else where with same vga cable to figure out whether its your monitor or your cpu tower.
Sep 02, 2011 | AOpen F2705 17" LCD Monitor
Why my computer is not turning on my monitor but the cpu is running
Need more information:
1. Are you sure the monitor is plugged into power?
2. Are you sure the monitor VGA cable is connected to the computer completely?
3. Is there an indicator on the monitor (a light).
4. When did it stop working? What changed?
Sometimes the power cord in the back or bottom of the monitor comes loose. Ensure all wires are securely connected.
BobB
Mar 24, 2011 | Computers & Internet
My compaq computersceen says input not supported
i think your cpu settings you changed to high resolution. That resolution is not supporting by your monitor. If you have another monitor connect to that monitor to your cpu and change lo some low resolution. If monitor is not there try to boot in vga mode for that mode you need to press "F8" button on booting. It show you some modes select vga mode and boot and change the resolution and restart your system
Jul 05, 2010 | Computers & Internet
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
How do i connect my Hannspree 22" monitor to my Dell Inspiron 1150 Laptop?
On the back of your laptop there is a vga connector, to the left are two(2) usb connectors and the right is your network connector . You need a vga cord (if you bought the monitor new it should include one.) Plug the cord into this port and into the back of the monitor. Plug the monitor in and the laptop should recognize thatthere is an external monitor connected and switch the video output to that monitor.
Take Care
Cammi
Nov 26, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
JM777 no receiving signal from CPU
when u power up the computer press F* key then go to enable vga mode then set disaply resolutin incotrol panel to 800*600 or 1024 *768
Nov 24, 2008 | Relisys TL 766 Monitor
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Dynex 32 in. LCD Flat-Panel HDTV Logo
96 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
