Question about Kenmore Kitchen Ranges
Kenmore electric range model 970-6860 fuses - Kenmore Kitchen Ranges
3 Suggested Answers
SOURCE: manual for kenmore electric range
I finally found a website where I could order the manual.
Thank you.
Posted on May 28, 2008
  • 9 Answers
SOURCE: Kenmore Electric Range Model #911 9237313-All burners quit at once?
Have you checked your fuse box. The Electric Range is on a separate circuit. Check to see if it is tripped or off.
If it has tripped and you reset it, that usually means there is a problem with the electric range.
Let me know if that helps.
Posted on Jan 22, 2012
Testimonial: "This did not fix the problem but easily could have been the reason my burners wouldn't work. I appreciate the suggestion."
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
How do I replace the Oven Temp Sensor or Fuse on GE Electric Range Model #JDP39WW1WW?
Here is the GE appliance service website: http://www.geappliances.com/service_and_support/
You will find an amazing source of information there. I hope that this helps!
Kim
Sep 06, 2013 | Kenmore 91112 / 91114 / 91117 Electric...
Jan 22, 2012 | Kenmore Kitchen Ranges
Kenmore Model 790. Burners work but the electronic buttons and the oven do not work. Is there a fuse for this? None of the display works or lights up.
You will need the control board for your range. I can direct you to the part if you can post the model number off the unit. Look in the oven for it.
Aug 03, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Broiler not working. How can I replace the fuses if that is the problem? Kenmore Range bought in 2002. Model C970-595081 Serial NF 2171 0264?
the model number you sent doesn't come up,is it gas or electric?if it's gas most likely it will be an ignitor.if it's electric probably the element.send correct model number off the machine,open the bottom draw,look at the left or right part of the frame and you'll see a tag with the model and serial numbers,just need the model
Mar 06, 2011 | Kenmore Kitchen Ranges
Kenmore electrical range
D Burns again... Replaced the 15 amp, type P glass fuses that are under the fluorescent light at top. $2.50 at Candadian Tire fixed the issue.
Jan 15, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
85 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
