Question about Samsung LN40D550K1FXZA - LN40D550 40 1080p LCD TV - 16:9 -
Power cycling Occasionally, (and tonight while I am trying to watch the Olympics is one time) my TV will repeatedly power cycle. Starts at 10 seconds on, 1 second off. Tonight it is the worst it has been. 1 second on, 1 second off.
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
Push the "menu" button on your remote
Tab over to the "time" menu
check all the settings in there, turn of the sleep timer etc...
Try a factory reset
Push the "menu" button on your remote and go to settings, scroll down and push reset.
I hope this helps
Posted on Feb 10, 2014
  • Jay Koch
    Jay Koch Feb 10, 2014
    Thanks. Actually, it turns out that the issue was not the TV, but the DirecTV unit. The TV was not turning off. It was losing signal from the satellite unit. The DirecTV unit had been on for more than a day. I turned it off for a few minutes, and when it came back up, it was fine.
  • iandunn_tms Feb 11, 2014
    Hi Jay, Great that it's working again, thanks for the update.
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
Picture one day, no picture the next
try resting the device again for few hours n then try
Aug 19, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
All three lights blinking picture only stays
I was having this same problem - power cycling - exactly as described. The lamp turns on and the picture looks good for the 5-10 seconds it is on (this makes me question all the comments I've seen online saying it is a bad lamp that needs replaced).
Problems started with green lines on analog channels and erratic behavior that included freezing and shutting off occasionally. Now, it is to the point where I get 5-10 seconds of picture, then it freezes and starts the power cycle 5-6 times, chiming every time it automatically turns on, before finally remaining off. I have removed the back, dusted off fans/components/etc, supplied additional fan for airflow, and made sure the blue switch in the back is down. Still having the same problem!
Ok. I went through the standard warranty process, which means they sent me a replacement bulb saying that was the issue. No luck...same power cycling. Finally they sent a tech out who took a look and said he needed to replace the digital board. So, 2 weeks later, the part came in and the repairman came back out to install it. Voila, I have a tv again. (This is the same fix the supervisor at the call center said it needed months ago...before they sent me the lamp)
So...I would recommend having the tv's digital board checked. Especially if your tv is still under warranty, as it cost me $0.00 to fix. Chances are, they are still going to start by having you replace the lamp. Good luck!
Jan 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv shuts off after 10-20 minutes
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
Jun 06, 2009 | Panasonic TH-42PC77U TV
Power issues-pt47wx53g
convergence ic's failed. probably took out some resistors and the pico fuse from what i am hearing from t.v techs. its like 50$ in parts if u can solder / desolder.
Oct 17, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Samsung HL5067W power cycling
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
Sep 29, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Samsung LN40D550K1FXZA - LN40D550 40 1080p LCD TV - 16:9 - Logo
Top Samsung Car Audio & Video Experts
Tom
Todd Arndt
Todd Arndt
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
