Question about Kenmore 22642 Top Load Washer
Kenmore washing machine will not stop filling
Once I start my laundry the water will not stop filling. Does not matter what load type, it just keeps filling until I stop it and then it will start, but when it goes to the rinse cycle, it does the same thing. I have to open the lid in the rinse cycle and then fiddle with the timer to get it to kick in to drain.
  • Kenmore Master
  • 16,043 Answers
There is a water level sensor in the tube and it might be plugged. IT could also be the load selector or the control module.
Posted on Feb 10, 2014
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
danromarris
  • 101 Answers
It sounds like you pump is clogged. If there is something stuck in your pump the motor can't spin it to drain the water. If that is the problem then it's easy to fix. Simply clear the pump and put it back on, just make sure to clamp off the hoses to the pump with hose clamps or you will have water every where. If that is not the problem though then it means that your timer is bad and that is a little more expensive. Try the pump first though and hope that that is all it is. If not, like I said, you will need a new timer but most likely your pump is just clogged with something that is causing the pump motor to not spin. It could be a coin or a hair pin or even a sock or something. Good luck and let me know if you have any other questions.
Posted on Jan 21, 2009
vanni7
  • 163 Answers
SOURCE: Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Posted on Feb 13, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Why would a washing machine fill to proper level and then stop. no action after filling.
Power was never the issue or it wouldn't have filled at all. Also the pressure switch that detects water level must be okay since it stopped filling at the proper level. That leaves the control board or a relay that the control board uses to start the drum motor.
Sep 16, 2014 | Washing Machines
My laundry room flooded when I ran a load of clothes in my kenmore he2 plus washing machine
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Feb 28, 2010 | Kenmore Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Keeps stopping after 10 seconds of operation
Motor is bad and needs to be replaced. It is drawing too many amps and tripping its overload. Once cool it will run again only to stop. About $100 for the motor.
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22642 Top Load Washer Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
