Question about JVC Cybercam GR-DVL725 Mini DV Digital Camcorder
LCD Monitor the display only displays 1/2 screen leftside is fine the right side is just grey
  • 188 Answers
SOURCE: LCD screen goes plain grey
i think it's the case of damaged flexible cable to the lcd screen from the camera. a replacement will do the job
Posted on Jun 28, 2006
0 characters
1 Points
The LCD screen monitor seems to be cracked in one corner. I have a replacement part coming. How do i remove the damaged screen ready for the new one. there are two screws on the camera side of the screen...
Very carefully you will need to pry the grey frame off of the lcd. But do this only after you are sure you have removed all of the screws. It is possible that you will have to dissassemble the whole camera in order to access some of the screws on the LCD assembly. Sometimes there are some right in or near the hinge.
Nov 30, 2010 | Panasonic PV-GS300 Mini DV Digital...
Last winter I dropped my Canon FS100, and the LCD screen would only display black or a grey strobe in camera mode. After a week of what seemed to be repeated attempts to reboot, it "healed" itself! Now a...
It might be that she damaged the lens where you just got it slightly wet. damaged the lens or the CCD that receives the image itself. it might not be repairable at all, If its a case of water damage remove all power sources from it and use a hair dryer on low for a while to dry it out " make sure the screen itself does not heat up to much and focus on the lens. You may have to replace the camera or contact a repair person. I myself give any repair a try and most things with a little luck can be saved.
Mar 28, 2010 | Canon FS100 Flash Media Camcorder
L C D panel is a blurred screen
ur lcd seems to be faulty dear need to check it .... der would be no display and only grey colour is being shown by lcd..
which model r u using i can provide u the lcd
Jul 14, 2009 | Sony Video Cameras
Dark screen- No images- some shadows horizontally
If you get a blank LCD, dimly lightened by a whitish back light, then the LCD display eis either faulty, badly connected, or the ribbon connector to LCD is defective.
The camera must be taken apart, ribbon cable tested, and eventually replaced and adjusted.
If all contacts on ribbon cable return continuity (cable is fine), then LCD is faulty, and must be replaced.
Althought the job is not too difficult, an user without experience may damage the camera in attempting this repair.
My first suggestion is always taking the unit to a camera shop.
Aug 23, 2008 | JVC GR-D90U Camcorder
DCR HC-42 LCD screen problem
Hi i had the same problem and i got it for the second time. can i please know how to remove the camera so i can replace the strip my self. And do u have a service manual. if so can i know where to get one for my self. thanks
May 19, 2008 | Video Cameras
LCD Side Screen Display Not Displaying
The problem is a bad CCD inside the camera. I Sony was providing free service for some of their other models but failed to provide service (recall) on these models. contact Sony at 1-866-703-7669
Feb 07, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
Image being displayed is all colored vertical lines
I had this problem a lot on Labtops. The problem is that it has been unliquifed in the screen. This means that the screen has been damaged or has got really hot. Also its has been on for along time. LCDs go bad real quick and can be a hassle when you need the infomation in the thing and have no display. When I had this problem on my labtop, I used the external bay to use another monitor so I can work on it. So I say that nothing can be done to fix it. The only way to see your stuff on there is to use the video out on the recorder and try to check your stuff. That multicolor lines you saw is becoming major right now in LCD displays. I hope this solves your problem.
Nov 13, 2006 | JVC GR-D22U Camcorder
LCD display is not working
the flex wire of lcd monitor has being cut.....and a message 'cover is not open' there switch inside the cover of the lens that is losing contact....
Aug 29, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Sep 14, 2005 | Sony DXC-190 Camcorder
JVC Cybercam GR-DVL725 Mini DV Digital Camcorder Logo
15 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
