Audio receiver (Pioneer VSX-804RDS) rather suddenly started to be really loud when turned on, problem seems to be the fan/fan motor
I opened unit and tried to clean with dust remover, but that didn't change the noise level; added complication: unit was bought in Germany (some 20 years ago), gets 220V via a transformer; replacing fan motor looks complicated - worth it?
4 Suggested Answers
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
Posted on May 17, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
My pioneer vsx-518 has a noisey cooling fan, is that normal?
Before replacing the fan, check for loose mounting hardware and cracked or damaged blades
Feb 09, 2013 | Pioneer VSX-518-K Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
Pioneer VSX-45TX turning itself off
check all speakers and wire not short... you can try open each speaker testing....
Nov 12, 2009 | Pioneer VSX-45TX 7.1 Channels Receiver
Pioneer VSX-517 was turne up lou. Showe
THERMAL SHUTDOWN PROTECTORS MAY BE BLOWN
Nov 03, 2009 | Pioneer VSX-517
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
Pioneer vsx-456
I have um Acquitance Groundbreaking VSX -456 as you I turn on appears Poweroff and he turns off automatically if he may go feasible ma ajudem,pois did not what to do. thank you Awaiting recurrence for its email: domingosdsm@globo.com
Nov 20, 2007 | Pioneer VSX-456 Receiver
Pioneer vsx d810 has no dgital functions
are you using digital audio?? you have to use fiber optic cables to get digital audio
Jun 17, 2007 | Pioneer VSX-D810S Receiver
Pioneer VSX-804RDS
Its really7 a hard thing to say what the problem could be. It could be the stanby power supply. The power switch the power transformer. with out troubleshooting skills it in your best interest to seek a pro to troubleshoot this for you. You could cause alot more problems by touyching the wrong things if your not carefull. Good Luck
May 09, 2006 | Pioneer A509R Amplifier
56 people viewed this question
 Grubhead
Grubhead
