Question about Cuisinart CPM-900 EasyPop Popcorn Maker Red 10-c
Base doesn't get hot
Popcorn doesn't pop because the base doesn't heat up
    Champion:
  • 252 Answers
You cannot repair home model poppers, return to store or replace.
Posted on Feb 13, 2014
When I turn on the heat for the kettle to warm up. the breaker kicks.
It's shorting out somewhere. One likely area is the heating element inside the kettle.
Sep 28, 2014 | Gold Medal Popcorn Poppers Pop-O-Gold With...
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
Will not heat up and pop
Your power cord I would follow into the machine and hunt for a broken wire or a blown fuse possibly. Most pop corn makers are just about like a coffee pot. They have a klixon to control the temp and a couple of bullet fuses in line to prevent over heating. All of which is loacted on the base of the kettle. I wish I could be there to help ya get that popcorn popper working. Feetball season is nearly upon us.
Contact the makers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 05, 2012 | Nostalgia Electrics KPM-508 Popcorn Maker
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
Jun 27, 2010 | Kitchen Appliances - Others
The kettle will not get hot! The light comes on and the #1 and #3 switch both light up, but no heat!?!?!
We disassembled the kettle and noticed that the black wire had been disconnected from the base connector which is attached to the heating element. We re-attached the wire clip to the harness and it heated up on the first try. Please note that you may need to crimp the wire connector to the base for a stronger hold. My guess is that as we were moving the unit back and forth the wire connector had seperated.
Aug 11, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
New Cuisinart Party Popper not heating
Align the tabs on the plate with the rectangular indentations on the base.
Squeeze tabs, set plate on base and release. This should lock the two pieces together.
Mar 29, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Popcorn popper motor base broken
you will need the manufacturer's name, model number of the unit and its serial number. You may contact any appliance repair shop in your area with that information and they should be able to help you. or you could go online to partstown dot com, and order the part directly.
Dec 18, 2017 | Paragon Theater Pop 4 Popcorn Maker
Popcorn won't pop
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
Nov 06, 2008 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Directions for presto carmel cormer model #0500001
I have the directions for this; send me your address and I'll mail you a copy or I could probably just I have a Presto Caramel Corn'r. These are the directions:
You need a large mixing spoon, wax paper and the following ingredients:
2 T cooking oil
¼ c popcorn
¼ c butter or margarine
½ c brown sugar
2 T light corn syrup
¼ t salt
1/8 t soda
Then follow these steps
1) Pour cooking oil and popcorn into the unit base. Place cover on base. Plug cord into base and then into wall outlet. The signal light will glow when unit is heating. When popping is completed, the signal light will go out indicating that the heat has shut off automatically. Unplug the cord from the wall outlet. Tip unit upside down so popped corn falls into cover. Set cover with popped corn aside. You may want to use a paper towel to remove excess oil and unpopped corn or hulls from the base before making caramel sauce. NOTE: I pop corn for all the batches I intend to make first then do the next steps because you don’t have to clean it each time to make a new batch.
2) To make caramel sauce, combine butter, brown sugar, corn syrup and salt in the base. Plug into wall outlet. Heat mixture stirring constantly until butter is melted and sugar is dissolved. Continue cooking, stirring occasionally for three minutes. Unplug cord from outlet and unit.
3) Place the mixing band on the base. Add baking soda and stir until mixture is evenly colored, light and foamy. Add popped corn, stirring to evenly coat with caramel sauce. Remove mixing band. Pour caramel coated corn onto wax paper and separate kernels. Let stand a few minutes before serving. Wash unit before popping more corn.
Aug 04, 2008 | Kitchen Appliances - Others
Popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the plate...it needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Cuisinart CPM-900 EasyPop Popcorn Maker Red 10-c Logo
65 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
