Question about Hayden-Harnett 1975-1999 Ford F250 Engine Cooling Fan Hayden 75-99 Ford Engine Cooling Fan 1998 1985
1985 F250 460 runs for 2 seconds but then dies
I've been having problems with my truck running for only two seconds but then it dies. I've replaced so far the ignition control module, the ignition coil, ignition coil cap, it has a brand new fuel pump in it. I even bought a brand new Holley carburetor for it. I've limited it down to the fuel cause when I spray carburetor spray into the carburetor I can keep it running. I'm thinking it might be my fuel pump relay but I have no idea where it is. If you can tell me where it is or if you have any other suggestions for me I would greatly appreciate to hear back from you. My email is deaks15@gmail.com
  • Tammie
    Tammie Jun 09, 2016
    I am having the same issue, have replaced the relays which are two black snap together relays under your hood, should be hanging under the cervo (cruise control)they are corroding like there is a short. I told my mechanic do not call me until you figure out what is causing this, tired of it. said he fixed it. My daughter whom I gave the truck to got about 90 miles up the highway on a very hot day and it just stopped, leaving her stranded out in the middle of no where for two hours before we could get to her. If you get any answers please send them my way
  • 30 Answers
If it is a carburated engine it should have a mechanical fuel pump on the side of the engine, if this is the case it will only pump gas when the engine is cranking or running. Disconnect fuel line at carb, crank engine and see if it pumps gas out of line, if not check filter and lines from carb to tank for stoppage or bending but more than likely you will have to change fuel pump.
Posted on Feb 10, 2014
  • Tammie
    Tammie Jun 09, 2016
    I have replaced the whole fuel system parts, but something is shutting off power to the pump and scorching my relays. Where would the short be? pretty sure it's a short somewhere.
Car startsfor a few seconds then dies
Fuel pump and filter are suspected, consider replacement.
Dec 07, 2013 | 1985 Chrysler LeBaron
Car dies at stop, or down-shifting into second gear.
try turning the idle screw counterclockwise. #5 in the pic below.
Jul 04, 2017 | 1985 Volkswagen Cabriolet
1985 F.I, runs for 3 seconds then dies...new pump 1 year ago, filter, last fall,truck is always maintained
I would check all of the fuses and wires first. Make sure the engine is getting fuel pressure, the right amount. Have you tested any codes?
Feb 05, 2011 | 1985 Toyota Pickup
I have a 1985 Chevy C/30 pick-up with a 7.4L 454. Truck has been running fine and about a week ago I was driving down the freeway and the motor backfired and and lost power and eventually died. I stopped...
85 with TBI only needs 13lbs of fuel pressure. verify that the fuel filter is clean. there is no easy way to ck fuel pressure, special adapters are needed, I dont have info here at home but there should be a relay for the pump, on the firewall and the oil pressure switch also powers the pump. did you replace the pump trying to fix this problem or did you just mention it to help troubleshoot the problem? verify that the fuel pump wiring has a good ground, should have been a eyelet that bolted to the frame..when you initially turn the key on, you should hera the fuel pump power up for 2 seconds, then go off, after the engine starts, the power for the pump goes through the oil pressure switch.
Sep 19, 2009 | 1985 Chevrolet C3500
85 vette starts but will not stay running
there is a sensor on the throttle body it' controls the idel of the vehicle it's called a tps and has a electrical lead to it this should be replaced it will be positioned right behind the butterflyplate of the throttle body
Apr 26, 2009 | 1985 Chevrolet Corvette
1985 Ford Pickup Loses Fuel Pressure then dies
The fuel pump relay, which is probably by the other relays under the hood by the big fuses, can surely be tired after all these years. Don't buy an off brand, I had one of those stick ON!
Apr 17, 2009 | 1989 Ford F 250
1985 Corvette, starts runs rough then dies
if you changed your fuel and that did not fixit its definitely the maf sensor.
Nov 26, 2008 | 1985 Chevrolet Corvette
Toyota 1985 22r pickup starts runs 2 secs dies starts runs 2min dies over & over
Check your plugs and distributer timing. Maybe try running some seafoam through your injectors.
Oct 31, 2008 | 1985 Toyota Pickup
Hayden-Harnett 1975-1999 Ford F250 Engine Cooling Fan Hayden 75-99 Ford Engine Cooling Fan 1998 1985 Logo
494 people viewed this question
Top Hayden-Harnett Computers & Internet Experts
ray gallant
RSole
Are you a Hayden-Harnett Computer and Internet Expert? Answer questions, earn points and help others
