Heller pach9 need a manual pls
I see the usual reply is go to Heller Im asking because there is no answer at Heller. I need a manual for a Gusty 10CO portable air con. I have searched Google ALL DAY.I need a better reply please
I did a google search and found only one link (below). I don't know if it is a con or a genuine manual.
In the absence of a dedicated manual you will have little choice but to gather information of a more generic type and apply it to your air-con. I expect most of them use the same working principle and similar component arrangement.
http://dattorrent.com/search/heller+portable+air+conditioner+model+gusty10co+m
Apr 01, 2017 | Heating & Cooling
Just moved into s property that has a heller DWH116 and it runs for 24 hours! Has this happened to you before? I read the manual and looked up online but I dont know what's wrong with it?
http://ernie.awa.com.au/Heller---Dishwasher/default.aspx u can find the manual here for it. in my opinion it sounds like a bad timer which can be changed but if it has quite a bit of age on it, then I would consider replacing the dishwasher itself.
May 21, 2016 | Hardware & Accessories
Heller breezy 15co
I have a manual for this machine. what is your question?
Jan 04, 2014 | Heating & Cooling
Heller MIST40B instruction manual
I am assuming this is not a dishwasher but a mist fan.
Try contacting awa in Australia who support Heller brand products.
Ph:
1300 366 144
email:
warrantysupport@awa.com.au
Jan 05, 2013 | Dishwashers
I need a user manual for a Heller oven with hotplates 26litre model number OVH6672
I've just moved into a flat with one, I too need a D/L of one manual REAL Bad!
May 02, 2011 | Toaster Ovens
Need manual for a heller portable air conditioner. Model: GUSTY10CO
I have a Heller Gusty10c0 Portable Air Con. When It hasn't been used for a while. I turn it on and it last about 10 minutes then just stops. Then when ever I turn it on it cuts out after about 30 secs to a minute. Can anybody help me please?
Dec 12, 2010 | Heating & Cooling
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Ric
Mar 09, 2010 | Refrigerators
Instruction Manual for HELLER automatic timer
hi can you tell what the cool or the hot pic are
Dec 07, 2008 | Hardware & Accessories
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
