Question about GE JTP15 Electric Single Oven
Jtp15w0a2ww Need part number for baking element. All I can find are ones for jtp15wa2ww unless these are the same model numbers
aborcass
  • 2651 Answers
SOURCE: hooking up new bake element
shouldnt make a difference your elemnt has only 2 terminals 1 wire to each
Posted on Mar 19, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
  • 289 Answers
SOURCE: Ge Model Number JPK27WOW2WW - when top oven is on
your unit is in preheat mode.the oven element is not coming on.
Posted on Nov 28, 2009
mreid542
  • 166 Answers
SOURCE: We need to replace the baking heating element of
Yes you can - yes it is worth it. First unplug or turn the breaker off to your unit. The bottom bake element is held in by 2 screws at the back of the oven. remove both of them and gently pull out the element a little. there are 2 wires attached to the element either by 2 more screws or push in connectors.
A lot of the time you can see where the element is burned out but sometimes you may have to check it for continuity with an ohm meter to tell if it is bad.
Posted on Jul 20, 2010
Testimonial: "this gives me courage to go the next step! Thanks"
SOURCE: ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Posted on May 01, 2011
Kenmore wall oven upper element will only come on when broil selected, not while bake is selected
Then you have a bad BAKE element, or the relay on the control board has failed. I would test the element for continuity ( since I have no model number to be more specific), and replace it if it is open or shorted, or if there is any blistering or breaks in it. Bake Element WB44K5012
Dec 12, 2016 | Kenmore Ovens
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
How to solder the ends back on a bake element
If the bake element terminal was shorted and burnt off, you will need to replace the bake element with a new element. Supply a model number and brand of appliance and I will supply a part number for you. Soldering will not hold as the solder will melt and break away shorting again. Possible to spot weld it if enough terminal left.
Mar 24, 2012 | Ovens
I need a baking element for the tappen oven model number 486847a. The stove serial number is VF41807648. Can you help
Go to www.ukwhitegoods.co.uk you will need the model number and serial number and place an enquiry. They will get back to you.
hope this is helpful
John
Jun 05, 2011 | Ovens
Oven will not heat, but burners still work
Without model number assuming burners on top and free standing unit.
The burners working tells you there is 240 volts to the unit. There are three possibilities, the bake element is burnt out, a wire is burnt off, a control part has failed. Bake elements can not be pulled unless the power is disconnected, because very often one side of 240 volts(120v) is wired direct so unplug, do not think having all controls off is enough. You can usually pull the bake element fairly easily by taking out two mounting screws and unplugging two wires. (these can go back on either way to the two terminals, does not matter just be sure tight) Take and have tested at appliance store, usually these test about 20 ohms. If that is good need to service from back and check voltages with a meter to find where problem in circuit is.....
good luck
Also check clock it is not accidentally in time bake setting, should be manual for most cooking (do this first before anything else)
Mar 14, 2010 | Kenmore Ovens
Bottom heating element burned out. Can I get a new one and how do you replace it?
You will need the model number of the machine, Once you have the model number, you can call a parts store to get the part you need.
When you have the part. Very important! First Turn off the power to the machine at the breaker box or sometimes called fuse box.
There are usualy 2 screws holding the bake element in, Remove them and pull the element out untill you see the end of the element and wires attached to them. NOTE : Go slow. You will see the wires at the end of the element. Just take a look at the new one to see what it will look like. Next, remove the wires from the old bake element, they are either screwed on or cliped on with a spade terminal. Take the old bake element and new element and make sure they match. now put the wires on the new bake element and reinstall. Then you can turn the power back on and test.
Nov 19, 2009 | Magic Chef 9815 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
FAN COMES ON
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Lower baking element has a hole in it
they get weak in some spots and do that,all you do is remove the 2 screws on the back of element pull out remove both wire jack and install new one,you can get one at sears .com,click on parts put in your model number and get your part-mike
Dec 26, 2008 | Amana AOCS3040 Electric Single Oven
Electricity getting to broiler element but not baking element
Get me the exact model number and I'll provide you a part number and the correct pricing info. That's way out of line, that part is probably less than $130.00 and is easy to replace yourself.
Dec 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE JTP15 Electric Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
