Question about Shark Navigator Bagless Upright Vacuum
Brush stops turning
Brush turns for one second and stops, red light comes on.
My beam Q100 power brush starts for about 5 seconds then stops power.
Take the brush out and check for hair & string around the ends where it goes into the bearings. Remove the crud and reassemble. NEVER oil the bearings. It will collect dirt and dust and gum up.
Jan 18, 2013 | Beam Q power Brush Q100
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Feb 06, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Brush will not stop moving when put in upright or bar floor mode. Also red power light doesn't come on when turned on.
Hi Chris,
I'm sorry to hear you're having difficulties with your DC28. I'd encourage you to get in touch with us directly, so we can provide further assistance in resolving this issue. Please call our Helpline free on 1-866-693-9766 - or if you email your contact details to us at askdysonUS@dyson.com, someone will be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 04, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
When the power head is turned on it goes from green light to red light and stops. The belt is fine and there is no obstructions in the brush to stop it from turning.
this will happen only when the brush or motor does not turn the right speed
make sure to pull the end caps off the brush and clean any hairs or fibers from it
the motor you can try and turn it by hand with out the belt on and see how free it is
Oct 19, 2010 | Fantom Vacums Lighting Canister Vacuum
Miele power nozzle quits after 10 seconds of working.
Even though the brush is spinning, you probably need to replace the belt2_bing.gifbecause it is stretched. It is probably slipping on the beater bar.
Jim
Nov 30, 2009 | Miele Vacuums
Even with a new battery
I was having the same problem. Roomba would run for 30 seconds and then stop. I tried everything -- then I took the small rubber brush out and removed the small nut at the end. It was packed with dust to the point that it could not turn easily. I cleaned it out and now it is working like a champ. I think the automatic shut down was just a sign that there was too much strain to turn the brushes.
Apr 21, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba turning off after 30 sec.
Nov 27, 2007 | Roomba Robotic Floor Bagless Vacuum
Shark Navigator Bagless Upright Vacuum Logo
24 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
