Question about Mitsubishi WS-65515 65" TV
Wont play Blu Ray or PS3 with HDMI
I used multiple different HDMI cables. When I hook the HDMI cable to my Laptop or Directv box it has no problem. My PS3 plays on multiple different tv's
tvtek
  • 1284 Answers
SOURCE: Mitsubishi vs-45609
You should have two antenna inputs A & B. Most commonly the RF or TV output on the back of the cable box is connected to antenna A and the TV has to be set for channel 3 or 4 depending on which station is not available in your area. If you don't get a picture on 3 or 4 then switch the cable box to antenna B or find the switch on the remote that allows you to remotly switch antenna inputs. If your TV has a connection that says "cable out" don't use that one as that is for a more complex setup. I hope this helps you.
Posted on May 02, 2007
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
dutchman05
  • 487 Answers
SOURCE: WD-52725, Denon 1508 and a PS3
use the component cables that will be your best bet.
Posted on Apr 29, 2008
charcois
  • 763 Answers
SOURCE: scrolling diagonal lines
try to see the input connection of it. it must have a loosen the connection everytime you put it. see also the settings or the menu it must have been out of tuned.
did you try to watch any dvd or vcd using your tv. see if still persist the problem.
cheers
CHARCOIS
Posted on Sep 01, 2008
VOTIT
  • 2071 Answers
SOURCE: connection
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Oct 10, 2008
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
How do I hook-up a blue ray HDMI to my AKAI HDTV thru a digital cable box?
If your TV doesn't have an HDMI port on it then you'll not be able to use the player. Some players have hi def output jacks, but it isn't true HDMI so using a hi def cable would defeat the blu ray players resolution when viewing a blu ray disk.
Nov 17, 2014 | Televison & Video
Does not switch to its external speakers
You have a cabling and/or setup issue and need to check your hardware manuals (or find them online) for instructions.
I have a Samsung HT-C550, a DirecTV satellite box, a Vizio 37" HDTV, a Sony 5-disk DVD player and a Vizio Blu-Ray DVD player, all peacefully co-existing (with the use of a bunch of cables as well as a Logitech Harmony 700 universal remote).
The TV (not the home theater) controls the use of the TV speakers.
There are multiple options to get this to work. I run an HDMI cable from the sat box to the TV. (HDMI sends audio & video to the TV). I then run an optical cable from the TV to the CT550 and use the "D-In" setting to get the sound to play.
Instead of the optical cable from TV to CT550, you can run audio from the sat/cable box directly to the CT550 using (red/white) RCA cables from the "audio out" jacks on the sat/cable box to the "AUX1" or "AUX2" inputs on the CT550"
Hope this helps!!
Dec 01, 2012 | Samsung HTC550 Theater System
Can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Jun 29, 2012 | Panasonic DMP-BD77 Blu-ray Disc Player -...
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
When sony blu-ray plays, lg 52lg70 tv power turns off and on. i connected sony to small vizio and it plays fine.the connection is hdmi.i hooked up a wii game and it plays fine. please help
Try using a different HDMI cable; one that is not simplay or 1.3.
The HDMI can control functions of the TV.
If you get a cheaper cable it may not do this.
Aug 30, 2008 | Televison & Video
PS3, playing blu-rays
I have a mate with this problem also . He rang Tv company and was told that model TV doesn't support blue ray so will not play .
Aug 25, 2008 | LG 42LC2D 42 in. LCD HDTV
Blu ray not playing on ps3
Could be an overheating issue.. Is there enough air circulation around the unit? Is it possibly dusty? try and perform minor servicing (use a can of compressed air incase if there's dust causing problems)
Does this happen on regular dvd's ?
Jun 15, 2008 | Sony Playstation 3 (PS3) Console
PS3 to XBR1 HDMI
hey, im hopeing the tech will be able to sort it out for you, theres not much any of us can tell you what he couldnt tell you tomorrow so be patient.
if he doesnt get it sorted drop us a comment and il try to help you.
Mar 23, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Mitsubishi WS-65515 65" TV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
