Question about DeLonghi DE500P Dehumidifier
Cf08E saying full when empty
The metal part of the float switch has fallen off & I need to know how to re-attach it do you have any diagrams?
  • boosuns Feb 10, 2014
    sorry this is the thin metal strip on the float from the CF08E Delonghi dehumidifier
Says bucket full and it is empty
There is a float switch somewhere to measure the level of water in the bucket. That switch is out of position or broken. This can happen if you are not careful removing and re-installing the bucket. Look at the area around the bucket and you should be able to find and fix the switch. Make sure the power is off when you are doing this.
Nov 13, 2013 | LG LD450EAL 45 Pint Dehumidifier
The float is broken in our dehumidifier, is it repairable?
Is the float in the empty or full position?? If it is in the empty position, and the unit will run normally, then yes you can. The water will divert from the evap tray right into the hose. If it is stuck in the full position, and wont run because it thinks it's full, you will have to find a way to put and hold it in the empty position.
Nov 10, 2013 | Danby DDR600R Silhouette Dehumidifier
Fill light on and beeps but holding tank is empty
If it is like mine, the plastic part attached to the float in the collection bucket is broken and no longer actuates the switch that indicates the collection bucket (holding tank) is full. When I checked several years ago, the replacement part was no longer available. I used tape to keep the switch in the position that allowed the dehumidifier to operate and attached the hose connector to allow the condensate to drain. The collection bucket isn't needed anymore with this arrangement.
Oct 24, 2012 | Maytag M7DH65B2A Dehumidifier
Haier 45 pint dehumidifier does not shut off when bucket is full. How do I adjust the float cup switch (forward or backward)?
If you want it to shut OFF before the tank is totally full, slide the float cup forward. if you want it to fill completely before shutting OFF, slide the float cup backward. Some folks prefer the half full, because the bucket is not as heavy to remove and empty, as it is when it's full.
Hope this helped you. Please let me know. Thanks.
Jun 29, 2011 | Haier 45-Pint Dehumidifier
The bucket full light stays on while it is empty. the humidity control doesn't change. the unit is not going on.
There should be a switch that is activated by a float lever that if tripped will make the bucket full light stay on, and will prevent the unit from going on.
If this light is on when the bucket is empty, maybe try to jiggle the float lever, or investigate why the switch is activated when the bucket is empty.
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Jun 04, 2010 | Dehumidifiers
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Float fell off in storage. digital screen keeps flashing to empty container. Where does float attach?
Not familiar with this unit, but the float has to be in the reservoir. It has an arm on it which pushes on a switch when it raises with the water level. The switch which the float arm presses is now pressed, which falsely signals that the reservoir is full.
Hope you can figure it out from this. If you have qeustions, let me know.
May 06, 2009 | Crosley MCR40ES Dehumidifier
Humidifier says "bucket full", not using bucket have hose attached
Offhand, two possibilities:
1. erroneous sensor reading(s) causing system to respond likewise erroneously; and/or
2. firmware/software glitch.
Initially, I would suggest a full hard reset, that is unplug from the mains for an hour or so. This would normally revert the unit back to factory default (assuming no hardware problem). Additionally, you may want to check the sensor(s) like the a bucket full sensor often would be a float switch of some kind.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 09, 2008 | Goldstar DH504EL Dehumidifier
Model LHD45EL; brand new; Says Full Bucket When Empty!
Bucket has to be firmly in place to engage the switch for the bucket full switch to go off. Also check the float in the bucket for freedom of movement.
May 09, 2008 | Dehumidifiers
DeLonghi DE500P Dehumidifier Logo
74 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
