Question about Canon DR-2050C Path-Through Scanner
Duplex Scanning Everytime I use duplex scanning I get a line down the middle of the scanned page. I have cleaned my scanner and still have the same problem.
  • 1 more comment
  • Anonymous Nov 28, 2007
  • Anonymous Jul 02, 2008
    same issue... with 2 different units!
  • setfinisher Aug 26, 2008
    Yes, same problem. The second page only has a line down it. Have cleaned the windows with a cloth as instructed but havde not tried achohol. It is in duplex mode when this occurs.
  • 490 Answers
If the line appears in the same location, it is definitely dust sticking to the glass. How thick is it? If it is thick, it may be because of an LED failed to glow, but this is etremely rare. If you are getting line in Duplex mode and not in simplex mode, it is on the second scanning module! Try cleaning with Isopropyl Alcohol (IPA). If you have been scanning old documents which tend to break like biscuit or get powdery, a speck can enter into the scanning area and create trouble.
S. Mohan
Posted on Mar 05, 2008
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
Only scans 1/2 back page in duplex scan.
%95 of the times its a technical faliure, Talk to the store you bought it from or call Panasonic customer support, you can not fix this by yourself. =)
Jun 08, 2007 | Panasonic KV S2045C Path-Through Scanner
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Getting vertical lines on scanned pages when duplex scanning on canon dr-3080c II scanner Only on duplex side of pages, though. Front page still shows up clean.
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Jul 10, 2009 | Canon DR 3080C Path-Through Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
Jul 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Canon DR-2050C Path-Through Scanner Logo
467 people viewed this question
old marine
old marine
