Question about Cameras
Cancilation of a bid - Cameras
I over bid on an item by mistake. Instead of $2.25 I clicked on $225.00 Ebay is closed at this hour & I can not fix this muself.
your bid only goes .50 cents more than the last bid,it is ok that you bid 225.00,that was the highest you could bid,but,you got it for only 50 cents more than the last bid,dont worry,go back to ebay and view your purchase,it will tell you how much you bid,or paid for it,if the item didnt sell,then you better hope that noone bids on it before the end
Apr 11, 2015 | Computers & Internet
How to cancel bid
Assuming the auction hasn't ended ... contact the seller to request that he cancels your bid ... give him a good reason ...
If the seller is good/nice about it, the seller will void/cancel your bid. Or, if someone else bids higher than you, then you're off the hook; i.e. no need to ask to retract your bid.
Oct 21, 2013 | Computers & Internet
How do I cancel a bid on ebay
There are two ways to cancel bids on eBay. The first is for the seller to cancel a bid made on their auction. The second is for buyers to cancel bids they made on other's auctions. Both come with very specific rules that prohibit any auction misconduct.
Canceling a bid made by someone else.
Review the reasons allowed for canceling a bid. Go to the cancellation page if the bidder is someone whose identity you have not been able to confirm.
You should also access this page if the bidder asks you to cancel the bid, or if the item being auctioned is no longer for sale. Fill out the cancellation form. Give the reason that the bid is being cancelled. Use the cancellation feature sparingly, as the cancellation and your reason for cancelling, will be recorded in the bid history. b> Canceling a bid made on someone else's auction. b> Use the bid retraction form to cancel a bid you have made. Make sure your bid meets the criteria for a retraction. Retract if the bid price you entered was wrong, and then correct the bid amount. Retract your bid if the auction description was changed and you no longer want the item as it is now described. Use the retraction form if you need the reach the seller for some reason and their contact information is invalid. Retract your bid that was made before the final 12 hours of the auction, as the option will not be available after that time. Retract bids made during the last 12 hours, only within an hour of the bid. Use the retraction feature as rarely as possible, as the number of times you have retracted a bid will appear on your feedback numbers. Hope this helps.
Dec 05, 2012 | Computers & Internet
Can someone see my max bid before bidding
the bid ammount was probably higher than it was it only goes up a certain ammount above your bid to the next bid and so on
lets say he bid $ 490 he would only pay the ammount needed above your bid
hope this helps
Jul 08, 2012 | eBay Auctions
How to make a secret maximum bid
When you bid on an item you can list your maximum bid. Ebay will increment your bid as someone out bids you, untill your max is hit. At the point your max is hit, ebay will email you that you have been out bid.
Jun 10, 2012 | eBay Auctions
Want to cancel my bid
Please do the following
1 Use the bid retraction form to cancel a bid you have made. Make sure your bid meets the criteria for a retraction. Retract if the bid price you entered was wrong, and then correct the bid amount.
2 Retract your bid if the auction description was changed and you no longer want the item as it is now described. Use the retraction form if you need the reach the seller for some reason and their contact information is invalid
3 Retract your bid that was made before the final 12 hours of the auction, as the option will not be available after that time. Retract bids made during the last 12 hours, only within an hour of the bid
4 Use the retraction feature as rarely as possible, as the number of times you have retracted a bid will appear on your feedback numbers.
Mar 20, 2011 | eBay Auctions
My daughter at claney8232 placed a bid for $10.00 and as she went to press . she pressed , instead which gave ortomatically submitted a bid of $1000.00 can we have this removed as our screen still shows...
You can withdraw a bid under certain circumstances.
From EBay page.... Find this in the EBay answer center, All about bidding,
However, honest mistakes sometimes occur. You can retract a bid if you have a valid reason for doing so as defined by eBay policy and you retract the bid within the required time period.
Valid reasons for retracting a bid include:
  • You accidentally entered the wrong bid amount. For example, you bid $99.50 instead of $9.95. If this happens, you need to reenter the correct bid amount right away.
  • The item's description changed significantly after you entered your last bid. For example, the seller updated the details about the item's features or condition.
  • You can't reach the seller by telephone or email.
Changing your mind is not a valid reason for retracting a bid. In the future, be sure to carefully review the listing before bidding.
If you want to retract a bid:
Jan 21, 2011 | eBay Auctions
Cancel my last bid 22800.00 my bid is a 228.00
Go on eBay. Open your user account. Click on current bids. All bids were shown. Open your specific bid. Click on cancel bid. Your bid is cancelled.
Aug 01, 2010 | eBay Computers & Internet
The sensig is on, and can't get back to normal cyle to wash dishes
try to just push the cancil button 2 times that should cancil anything he did if this does not work then you have a problem with the dishwasher
Nov 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
