My aughter's d600 screen went very dim and someone suggested replacing the backlight. Are there instructions somewhere? Does this sound like the soultion?
-   I have the same problem But i did replace the lcd screen with another but I have the same problem. There is almost no picture but when I connect an external monitor it works fine. Any ideas? Is it the mother board?-   fsca43
Nov 10, 2007
-   I have a similar problem, the screen is too dim to work with. The external monitor port is working ok when hooked up to a crt display.-   BeeRad
You also might check to see if there is a HOTKEY setting for the brightness of the screen (usually FUNCTION or FN and then some key on the top row).
Replacing the backlight on an LCD is a very advanced and trouble prone procedure, unless you are good with soldering and taking things apart, you should probably use it with an external monitor or think about getting a new machine. :>|
Umm the backlight is the hardest thing to replace and only 50% of the time the problem. More common is for the inverter to fail.
Did the LCD have a red tint before it failed? if not its probably the inverter. If it did then its probably the backlight, but its best to
test the inverter using a known good LCD first.
If you dont have one, then any repair shop that deals with laptops should be able to diagnose this pretty quickly (you shouldnt pay more than a 1/2-3/4 hour labor to take apart and diagnose.
if it really needs a backlight, it is a very difficult thing to replace the backlight - i see more people break the screen or electronics on the LCD trying to replace a backlight. always try an inverter first which is only about $20-$50 for the dells.
If it really has a bad backlight, you can buy good screens for the d600 for $60-$120 on ebay depending on what lcd it takes. You can find out what LCD by the service tag.
