Question about Carex 26 Inch Ez Grabber Reaching Aid - Colors May Vary
Ez Grabber 2 capture card... xbox dosent show up on the software that it came with
How do you edit with the ez grabber vc500
Hi
I give below a link to the EZ Grabber installation manual.
http://www.derbymagic.com/files/EZGrabber_manual.pdf
I have been through this but can find nothing to indicate an "edit" facility.
I then tried this link
http://www.dmmdownload.com/downloads/CURRENT/PVR/Diamond%20VC500CXT%20Walkthrough%20Response.txt
which clearly indicates an edit facility via some Arcsoft software which presumably is supposed to come with the grabber.
It is possible that one of the "software utilities" on the webpage (link below) may contain the software required.
http://www.diamondmm.com/driver-downloads.html?option=com_content&view=category&id=599&Itemid=1014&select_item=354_598&select_item_354_598=355_599
Good Luck
Aug 25, 2014 | Diamond Multimedia ( VC500) Video Capture
No Auto Stop on EZ Grab when VHS is done playing
hi, as long as you don't have a professional VHS player/recorder with a serial control, and a dedicaded software to control it, it is impossible for your soft to know that VHS as finished, you don't have the problem with a firewire input, as the control passes by the FW cable in the two directions, but you can solve that (easy way) by setting up the capture time to approach the real timing !
for the MP4 format, the easy graber doesn't capture in this format without the use of the CPU, because it doesn't have hardware encoding, so that's why you can't reach good quality by capturing directly on MP4, you would need a card like hauppage game capture to have full MP4 (H264) hardware encoding with really good quality, and without any CPU use !
Mar 13, 2014 | Diamond Multimedia ( VC500) Video Capture
What software works with ez grabber video cap device
I've had success with Pinnacle 9 a few years back also Ulead Studio 11
Sep 03, 2017 | Mygica Ezgrabber Video Capture Adapter...
I need a driver for easycap usb capture card
http://www.szforwardvideo.com/support/index.html
That should link you to the drivers for your usb capture card. I believe the category you must select is "
USB Video & Audio Grabber". Make sure you choose the correct model. The directions should be pretty straightforward to follow. If you can't find the directions, I've posted them below.
• Download the DC60+ Video grabber with audio drivers and utilities file to your computer.
• Unzip this file to a directory you will remember, such as DC60+.
• Uninstall the old drivers for Video adapter with audio from your computer at first, and leave your DC60+ Video grabber with audio plugged into your PC or laptop.
• Run setup.exe, from the directory file.
• Plug DC60+ Video grabber with audio into your PC or laptop, and click "OK" or "Next" to update the latest drivers. Please find the installation step through Quick Installation Guide or Software and driver CD.
Name: dc60+ driver.rar
Mar 22, 2011 | Computers & Internet
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
My Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Sep 18, 2009 | Ulead Videostudio 8 for PC
Vcr to dvd
Hi you could install a Video Grabber or an Internal TV Tuner card into your computer if its Desktop computer or an expensive USB TV TUNER if its for laptop . Plug in the composite video out from your VCR to the Composite Video in to the computer .Use nero or any other software to build a movie in fact the bundled application software of your TV TUNER or VIDEO Grabber card would be better .
May 09, 2008 | Dell Inspiron 5160 Notebook
Carex 26 Inch Ez Grabber Reaching Aid - Colors May Vary Logo
691 people viewed this question
Top Carex Home Experts
john h
Tom Chichester
Are you a Carex Home Expert? Answer questions, earn points and help others
