Question about Maytag Washing Machines
Broke the plastic screen that goes to the cold water inlet valve?
My machine would only run a trickle of water into the tub so I checked the water lines for clogs. The hog water line filter was clogged but I cleaned it up & replaced it. The cold water filter on broke upon taking it out. I am afraid that a piece of the plastic filter might have come loose & went into the machine somehow. So I decided to try to run a load of clothes. Now when the cold water valve is on the cold water constantly trickles into the tub. The machine did run a load ok, but I had to turn off the cold water line between cycles What do I do to repair this.
  • 998 Answers
The broken bit of filter has probably got stuck under the rubber diaphragm in the inlet valve. You will have to strip the inlet valve and remove the piece. There should be 3 or 4 screws holding the valve together. Make a note of how it comes apart. There will be a spring, a metal plunger and the rubber diaphragm inside the valve.
Posted on Apr 27, 2017
  • 1314 Answers
SOURCE: GE Washing machine cold water barely dribbles in
well the first thing i would do is take the cold line loose from the washer get a large bucket and open the cold line with the hose off and see what kind of pressure there is if very little need a plumber or in crese your well pump pressure check your screen while you have the hose off if all of this is ok id replace the washer water valves
Posted on Jan 19, 2008
  • 32 Answers
SOURCE: Cold water only trickling into my washing machine
unfortunately it sounds like you have a stuck plunger in the cold side of your water inlet valve.if the screens are clear and your water pressure is good,thats what you have.
Posted on Sep 28, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
Posted on May 23, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 90 series need to replace the inlet valve
This is actually a simple repair that the average Do-It-Yourselfer can perform with just a little guidance. The following link explains all the steps necessary to replace a water inlet valve on a Kenmore top loader:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If you have questions along the way, please let me know. A replacement valve can be purchased online at searspartsdirect.com, appliancepartspros.com, repairclinic.com, or pcappliancerepair.com. All these sites offer competitive pricing and excellent service, so shop all of them for the best price. Use your model number for your search criteria. If you do not wish to order on line, use the part number found at the sears or appliancepartpros website and go to your nearest appliance parts retailer. This is a part that is commonly carried as part of the in store inventory. I hope this helps you.
Posted on May 24, 2009
How do I lift the top of kenmore washer model 29422800
so what up we know water goes in so whats the actual erros and why are you lifting the top off it
Mar 05, 2015 | Kenmore Washing Machines
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Mar 05, 2009 | Kenmore Washing Machines
Cold water into tub of wash machine
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Cold water feed into tub seems somewhat pluged.
8. re-try.
Sep 25, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
