Question about Vehicle Parts & Accessories
S430 vacuum pump
Door locks, and trunk do not work. key fob works. could it be only a fuse or does vacuum pump need replacement and where is it located on a 2000?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Common problem on benz vehicles with pse pump failures. most likely not a fuse. the pse pump is located in the lt trunk panel area.
Posted on Jun 02, 2014
Trunk release wnen key, remote and button are inoperative
The fob is probably dead, needs a battery...if your doors dont lock with fob that would confirm this, and I believe there is also a fuse for the door button...will work when car on but not when off is a blown fuse I think.
Feb 08, 2014 | 1997 Saab 900
2006 Cadillac STS driver side door lock doesn't activate when I approach the car (as it's supposed to). Key fob also doesn't activate the lock or unlock features. All other doors and trunk operate...
It actually sounds like the micro switch in the drivers door that reads the key fob is bad, if the key works and the fob works on the other doors and the trunk. You will most likely need to have the door handle replaced, they're not very expensive by themselves but it can be a lot of work. Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen The video is a 2008 cts but will give you a good idea of whats wrong and whats required to fix it
Feb 03, 2014 | 2006 Cadillac STS
1996 S420 has new battery in fob, has been reprogrammed. fob works the lights on rear view mirror but will not operate locks. A local mechanic said it needs a new vacuum motor pump that is located under...
try and pull drivers door switch and replace,also change fuse in trunk.If that don't work ask the benz world .org forum to sho you how to rebuild pump for cheap.
Aug 21, 2013 | Mercedes-Benz Cars & Trucks
Mercedes S430 trunk won't open
you have to stick the key in the trunk and turn it to the lefy while hittin the unlock button on the key pad 35 times has to be 35 and it will unlock. my battery died and it locked the trunk as u know i coudn't jump it cause the battary is in the trunk haha but yeah 35 times while hitting the key. mercedes wont tell u but my buddy works for inskip and filled me in your o so welcome from one s430 owner to another
Jul 15, 2012 | 2000 Mercedes-Benz S-Class
2002 buick century key fob problem
Sounds like the remote receiver module in the car is malfunctioning and will probably need to be replaced.
Apr 14, 2017 | 2002 Buick Century
2001 Mercedes 430 Doors won't lock-trunk won't unlock--OBDII reads 888 Sounds like fuse. Can you help?
Hi, if all of the locks on your Mercedes fail to open (or close) first check your key fob to make certain that its battery is working. Replace the worn out battery, if necessary. If key fob is working, you may have a faulty key fob, which can be repaired or replaced by taking it to your dealer.
If just one lock won't open on your Mercedes, then the problem may rest with broken wiring, a bad solenoid, or perhaps with a blown fuse. Check your fuse box first to determine if a blown fuse is keeping the lock from working. If so, replace the fuse.
You likely have a shorted door lock actuator, which you can replace with a new unit for the lock that is not working. If a door unlocks, but will not lock again, then replace the door switch.
Besides there is not OBD II 888 code, i have never heard or seen it before...
Feb 07, 2011 | 2003 Mercedes-Benz S-Class
2000 Olds Key fob - only the trunk release works.
The buttons on the key have gone out. Check with your dealer for another key fob.
Jul 02, 2010 | 2000 Oldsmobile Intrigue
But a used 2006 solara but key fob does not remotely open trunk. Any suggestions?
Yes, insure that you have power to the trunk lock inside trunk, If not could be lose/broken wire or shot fuse. I am sure the key fob does work for the doors? If not have key fob battery replaced. Also, a quick check on power to trunk lock, check to see if have remote power button inside car, if it works power is good. Defective key fob would then be indicated.
Sep 18, 2009 | 2006 Toyota Solara
Central locking
Probably a leak in the vacuum system or a failing vacuum pump. It's common on these cars. The locking system is driven partially by a vacuum pump (in my A4 it's in the passenger side rear corner of the trunk, below the carpeting). Most likely you'll need to replace it, but try changing the battery in your key fob first.
Jun 01, 2009 | 1997 Audi A6
Car will not unlock.
To get inside the car .... Use the key in the lock cylinder, unlock the drivers door to get inside. You shouldn't have to reprogram the fob unless it or the keyless module was changed. There may be a blown fuse that supplies the keyless control module (check the owners manual for location). or wires that lead into the Drivers door may be damaged ... The keyless module is located inside the drivers door at the bottom behind the door panel ... do the unlock/lock and trunk release switches on the inside of the drivers door operate the locks and or trunk release? If so it is not the fuse ... and not the wires to it ... And it could be your BCM body control module, located in the dash board to right of your gas petal. Because the number entry keypad (code for that is on the inside of the right passenger trunk bracket arm) also doesn't work I assume it's not the key fobs themselves. Your 98 manual is correct for your car.
Apr 02, 2009 | 1998 Mercury Grand Marquis
Vehicle Parts & Accessories Logo
78 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
