Question about John Deere Garden
Stx30 gearbox stuck in first gear
Stx 30 gearbox stuck in first gear, shift lever loose & will not engage
SOURCE: The 4WD gear shift is
I don't know what year yours is, but my 2000 has to be in "N" to switch into 4WD. I hope that helps
Posted on Dec 08, 2008
  • 86 Answers
SOURCE: Craftsman lt1000 with manual transmission,
The detent Shaft inside transmission lost its ball and spring if its working outside transmission,could be other damage .
Posted on May 09, 2009
cnsimcoe
  • 16 Answers
SOURCE: My gear lever will shift out of park but will not
sounds like the linkage is unhooked or broke
Posted on Nov 29, 2009
SOURCE: Gear Shift lever loose
There are two torx bolts that hold the shifter to the column. You can see them with the lower column cover off (must first remove the ignition cylinder). If the lever is loose, these bolts are the first thing that I would check. That the identical problem on my villager.
Posted on Jun 29, 2010
  • 5370 Answers
SOURCE: Ford Explorer, gear shift lever
Take off the top cover of the steering colum, drop the colum down with the adjuster, take a small pair of vice grips, clamp it around the shifter indicator cable atachment. This will alow you to shift gears, (from rev to drive),no park. Just set the parking break, turn it off. Your key will not remove until you tie down the switch that is at the bottom of the shifter slot. Your shift lever will make it close when you put the truck in park. Then you will be able to remove the key. Click this link directly to see the internal shift lever parts,its adjustment and replacement:---- http://technoanswers.blogspot.com/2011/02/gear-shift-lever-adjustment-and.html ---------------- Also the bolts needs to be re-tightened to hold the lever,if they have got loose:--- helpmech_76.jpg
----------- This will help.Thanks.Helpmech.
Posted on Feb 12, 2011
Tip
UNABLE TO SHIFT INTO GEAR LEVER STUCK, LOOSE OR ONLY SHIFTS 1 WAY (either up or...
LEVER STUCK, LOOSE OR ONLY SHIFTS 1 WAY (either up or down)
Check that its not just the gear pedal either stuck on its pivot shaft due to corrosion, & that it is not just spinning round on the gear change shaft
If stuck in gear, try rocking the bike back & forward while moving the pedal up & down
If not then its probably the gear selector mechanism - hopefully on the accessible part.
If the gearbox only shifts 1 way then its probably just a broken / dislodged spring on the claw mechanism.
Remove the right-hand engine cover & check that the shift shaft operates the claw (which turns the gear selector drum) & that all springs etc are OK.
Otherwise its on the internal part of the selector mechanism either the shift drum is stuck or more likely the shift forks are worn or broken. Either way it will require a full engine strip
Ride Safe
Bike-Doc
on May 12, 2010 | Motorcycles
Gears stuck
Unlees you have had a loss of gear oil this is unusual.
I would first remove the linkage on the gearbox and see i i could manually move the shifter. Obviously, if i could, then the fault is in the shift rods or lever.
If the gear shift on the bix is jammed, the box will gave to come out for strip down and inspect or get another gearbox.
Cheers
Roger
Apr 16, 2014 | 1998 Toyota Corolla
Yamaha FZR 1000 2gh Genesis 88 model gearbox stuck in 1st
Hi, Vicky and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return spring weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
my 92 is stuck in first gear VMaxForum net
http://www.r6messagenet.com/forums/r6-maintenance-technical/78392-heelp-bike-stuck-first-gear-wtf-i-cant-get-out.html
DOWNLOAD NOW Yamaha FZR1000 FZR 1000 87 95 Service Repair Workshop Manual...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Jun 25, 2013 | 1988 Yamaha FZR 1000
Stx 30 Starts, runs until attempt to engage electric clutch.Thanks
I have a John Deere STX30. I can start it, but when engage into gear it die completely!
Jul 06, 2011 | John Deere Lawn Tractor Seat F710 F725...
Hi, I own a 1997 Ford E 350 Econoline, I have the following transmission engagement problem: Truck will not start: Transmission will not engage any gear, neutral or park. The shift lever feels like is not...
The weld on the manual lever is known to break loose. First, with the wheels off the ground, with the lever in the park position, does the drive shaft lock in park? If yes or no sometimes, drop the trans pan. I bet the nut on the lever camd loose.
Mar 31, 2010 | 1994 Ford Econoline
Won't shift into overdrive when button pushed
check gearbox oil level remove gear lever switch check feed to switch with meter or test lamp no feed check fuse if ok put 2 wires together car in 4th gear ignition on should hear click from overdrive solenoied if ok fit new switch if not check wires from lever to gearbox for breaks think you might find problem here if not check inhibitor switch and then solenoid hope this helps you
Dec 09, 2009 | 1992 Volvo 240
I can shift into any gear but only first is engaged.
One of the gearstick joints has disconnected - hopefully not actually inside the gearbox. Gearstick connects to gearbox via a few rods & joints or a pair of cables in sheaths. Check something visibly moves near the gearbox no matter what movement the gearstick makes.
Sep 09, 2009 | 1999 Volkswagen Beetle
My car turns on but it wont shift into any gear
dear friend-your blinker light has nothing to do with your gearbox problem,i surgest you have a look at the hazard switch.regarding you gearbox problem i think we must start at the gear lever.make sure that when you press the button on the shift that it does dis-engage,then while having the shift in hand move the car forward and back wards,try to dis-engage,if not you will have to remove the sump and look at the meganism inside,it has a half moon operating the shaft that is connected to the lock meganism.
Jul 18, 2009 | 2001 Hyundai Tiburon
Car will not drive, is it clutch or cabel
my daewoo lanos wont shift into gear/s while running even when clutch is depressed all the way
Nov 12, 2008 | 2001 Daewoo Lanos
Garden Logo
15 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
