Question about 2000RS-M Remote Starters Manual Transmission with Two 5-Butto
Galaxy car starter light stays on - 2000RS-M Remote Starters Manual Transmission with Two 5-Butto
2007 dodge caliber has full power to all electronics. The engine light stays on and when you turn the car to start nothing. Turning the key does not even deam the lights like the starter is getting no
Sounds like the solenoid on the starter is not getting any power, check the small wire connection on the starter to see if there is power in the start position, if not you have an ignition switch problem or an open circuit between the ignition switch and starter solenoid... if you do have power in the crank position then you have a bad starter.
Jan 11, 2015 | 2007 Dodge Caliber 2.0
2004 scion xb won't start, does not turn over, battery is good
You car have security system.first locate the security light and make sure goes OFF after unlocking the car
turn the key and monitor the instrument cluster if all the light stay on
apply parking brake and whit left hand turn to starting position and with right sift from PARK to NEUTRAL
locate the starter and connect test light to small signal wire,other end to ground. let helper start the car. did the light go ON?(replace the starter)
the light stay OFF (electrical problem)
Inspect all the fuses,switch the starter relay with known good one,clean battery terminals,scan with advance scanner for malfunction code,and switch to live data Look for starting signal from computer
good luck
Aug 25, 2014 | 2004 Scion xB
I start the car and the starter stay ingage I turn the ign switch off then try to start and the same thing happened few times until it start normal do you think its the starter / starter realy or ign
I would suspect that the solenoid contacts need replacing as they may be burning together. Pull the starter and have an accredited auto electrician bench test it.
Mar 11, 2014 | 2005 Chevrolet Malibu Maxx
1998 mazda millenia car will crank engine shudders when trying to crank. Starter engages when the key is in the on position.. starter stays engaged when engine is running
its one of two faults a starter fault or a switch fault,,
test the switch by hooking a wire to the small terminil on the starter and hooking a 12 volt light bulb up to it,,,now turn the key,,this bulb will light up,,,only for the time the key is held in the start up poshion if it stayes light up when you have let go the key the key switch if faulty
Aug 21, 2010 | Mazda Millenia Cars & Trucks
Expedition will not but interior light stay on
check battery. if not batterry then maybe bad starter or starter relay
Feb 05, 2010 | 2000 Ford Expedition
Galaxy GALAXY 5000RS-2W-1 Remote Starter, alarm is triggerd alot, door or hood open everytime.
spray WD-40 on the hood pin switch and the door latch, not unless your car is a ford, it could be the R.A.P system shutting down, diodes may need to be installed
Jan 25, 2010 | 5000RS-2W-1 Remote Starter with...
MY FORD GALAXCY WONT START ALL LIGHTS ON ENGINE TURNS OVER BUT NOTHING ELSE
Turn key on don't crank engine listen for a grunt sound from back seat area turn your head to the right if you hear no grunt fuel pump is not working.
Dec 27, 2009 | 1998 Ford Escort
Change battery
The anti theft light will stay on in this model that's normal if it doesn't start. You need to check for power to the starter. You likely have a bad starter.
May 11, 2009 | 1997 Buick Skylark
Battery light stays on
05 mazda 3 battery light stay on the battery is good an the alternator good
Feb 28, 2009 | 1982 Ford F 150
Galaxy 2000 Rs-m
yes, you can connect the tach sense wire from the controller(2000rs) to a fuel injector , and select tach monitor in the programming (see manual, available at scytek.net) and it will automaticcally adjust the starter crank time, other way to go is to install a delay card, sutch as the k 141 multi mode timer, and set it to crank for 3-6 seconds when triggered
May 26, 2008 | Scytek 2000RS-M Remote Control
2000RS-M Remote Starters Manual Transmission with Two 5-Butto Logo
Top Scytek Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
