Question about Apple iPod touch
How to open a disable ipod - Apple iPod touch
  • 56 Answers
Restore it or try updating the iOS via iTunes.
Posted on Apr 09, 2014
I need to change my password but my 5s isnt allowing me to do so
Go to iphone setting - then passcode or touch id & passcode. now tap on change passcode and then enter your old passcode and then new passcode. And if you forgot your passcode and your ipod iphone disabled and you want to unlock disabled iphone ipad.
here is the detail procedure
First method you can restore your ipod. But this will erase all your data on ipod. So if you have recent backup then go for restoring ipod. For that just connect your ipod to computer- then open itunes. Make sure you have installed latest itune version otherwise update your itunes first. Now open itunes then find your ipod under deivce tab at the top left sidecorner. Click on your ipod icon. Click on summary and then click on restore.
You can also restore your ipod from old backup also. For that open itunesfind your ipod under device menu. Now select your ipod and then right click on your ipod the you will get options for restore from backup.Select restore from backup this will provide list of all your previous backup on that computer itunes. Now select your backup which you want to restore and then click on continue. Once your restoring is completed your ipod will shut down and then again restart your ipod it will take few minutes to start up. And it also asks few information about you. Once you complete all that procedure your ipod is unlocked which was disable or locked due to wrong passcode.
Dec 26, 2016 | Apple iPhone 5S
MY IPOD SAYS IPOD IS DISABLE AND I NEED TO OPEN IT
if it doesnt go back to normal in 24-48 hours then connect it to itunes
Feb 10, 2014 | Apple iPod touch
IPod touch disabled
You are correct. Connect the iPod to a computer and then open iTunes. Select your iPod from the device list and then click the restore button.
Hope that helps!
Nov 04, 2013 | Apple iPod Audio Players & Recorders
Password forgotten now say's disabled
Unlock a Disabled iPod
If you own an iPod Classic or iPod Nano, you can set a four-digit security code on your device and then lock it to keep other people from accessing it.
Disabling your iPod is a good way to protect the data on your device, but if you lose or forget the four-digit code, you will need to manually unlock it in order to access your music and other content.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
Or
Hard Reset a Disabled iPod Touch
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
http://support.apple.com/kb/HT1808iOS: Unable to update or restore
Jul 30, 2013 | Apple iPod touch
How to restart a disabled ipod
If you enter the wrong passcode repeatedly on an iPod Touch, it will display a message that says "iPod is disabled." At first, the iPod will only be disabled for a minute, but if you continue to enter the wrong passcode, it will become disabled for longer periods of time, and finally, you will need to connect it to the computer with which you last synced it. From here, you will need to restore the iPod Touch to factory settings.
Open iTunes. Click "iTunes" in the upper-left corner, then select "Check for Updates" to ensure you have the latest version. Connect your iPod Touch to your computer with the USB 2.0 docking cable. Click your iPod's name under "Devices" on the left-hand side of the iTunes browser. Click the "Summary" tab. Click "Restore." Follow the prompts in the dialog box that appears to finish the restore. Your iPod will return to factory settings. Choose to set up the iPod as a new iPod or from a backup in the screen that appears when the restore is complete.
Apr 13, 2013 | Apple iPod touch
How do i fix my disabled ipod
Step 1:
Mar 29, 2013 | Apple iPod touch
What does it mean when my ipod says ipod is disabled
it means you cant use your iPod
hope this helps
Oct 04, 2012 | Apple iPod touch Second Gen (8 GB,...
Ipod is disabled........connect to itunes
There is a high chance that either you or someone tried to use your iPod and kept entering the wrong passcode. After a certain amount of tries, your iPod will become disabled. Here is how to disable it.
Step 1: Plug your iPod into your computer and open up iTunes.
Step 2: After a few moments, scroll down the left side of your screen until you see your iPod. Select it.
Step 3: The right side of your screen should now show the general information about your iPod. Scroll down the right side of your screen until you see a button labeled "Restore"
Step 4: Click OK. Give it a few minutes and your iPod will be restored to factory settings WARNING: ALL THE INFORMATION THAT WAS ON YOUR IPOD WILL BE ERASED. Once the iPod is restored, it will be able to sync with whatever is in your iTunes library.
Feb 23, 2011 | Apple iPod touch
My ipod is disabled
Feb 15, 2011 | Apple iPod touch
My ipod touch is disable.it tells to connect to itunes
plug in your ipod to your computer open up itunes and when your ipod appears under the devices section click on it and then under summary you can restore and reset the ipod
Oct 15, 2009 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
