How to reset pickup roller on samsung clx 6220fx after replacing the pickup roller on tray 2
  • 138 Answers
SOURCE: Tray2 Paper emty message after swapping out tray2 pickup roller
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Posted on Sep 10, 2008
pdouglasss
  • 125 Answers
SOURCE: Tray 2 Open or Empty message
If the flag is not set correctly it will give you that error. Make sure flag is seated correctly.
Posted on Jan 07, 2009
frankzjm
  • 191 Answers
SOURCE: How to replace a pickup roller in Tray 2, HP LaserJet P3005n
please reference here:
https://www.laserpros.com/hp_P3005_tray_2_pickup_assembly.asp
hope you fix it well
Posted on May 13, 2009
  • 92 Answers
SOURCE: Samsung CLX 2160 "paperjam2" problem
Hi ...
IN CLX 2160, paper jams usually occur in three areas of a printer. The following error messages indicate the area in which the jam has occurred:
  • Jam 0 indicates the paper failed to pass through the first sensor.
  • Jam 1 indicates the paper failed to pass through the second sensor and has jammed around the toner cartridge.
  • Jam 2 indicates the paper failed to pass through the second sensor and has jammed near the fuser.
Your error shows paper jam2 but i am giving you directions to fix the paper jams indicated by each error message so that you can handly any kind of paper jam issue with your printer.
Paper Jam 0 When your printer displays Jam 0, paper has failed to pass through the first sensor.
To remove the jammed paper, follow these steps:
  1. Power your printer off.
  2. Open the cover of your printer.
  3. Gently pull the paper toward you to remove it from the printer. Note: If you do not remove the paper slowly, you can damage the printer and the printer will require service.
  1. After removing the paper, make sure there is no additional paper in the paper path.
If your printer still displays Jam 0 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 1 When your printer displays Jam 1, the paper has failed to pass through the second sensor and has jammed around the toner cartridge.
If your printer still displays Jam 1 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 2 When your printer displays Jam 2, the paper has failed to pass through the second sensor and has jammed at the fuser.
If your printer still displays Jam 2 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Please vote if this helps ... Cheers :)
Posted on Jul 29, 2009
  • 406 Answers
SOURCE: How do I replace the tray 1 pick roller for my
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
Posted on Jan 07, 2010
Paper jam 1: where is the fuser area
Good God. If you don't have a manual, do a search on Google, or call to speak to a tech help person.
Oct 01, 2014 | Samsung SAS CLX6220FX CLX-6220FX...
My Samsung CLX-6220FX Printer says the paper is empty in the MP tray
Power the printer off, make sure all the trays are all closed properly, then power it back up again. Your printer is fine, the error will stop after restarting it in a full circle.
Aug 01, 2012 | Samsung CLP-500N Laser Printer
My Samsung CLX 6220Fx says to replace the pickup roller
Dear
It will better to call the trained service person to do the job.
Thanks.
Apr 02, 2012 | Samsung Office Equipment & Supplies
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
How do I replace the tray 1 pick roller for my samsung CLX 3160FN printer?
Jan 07, 2010 | Samsung CLX 3160fn All-In-One Printer
Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung color laser MFP CLX-3175FW. Paper jams after the first page is printed and continues to jam each subsequent page. This is the third printer we have tried. Using a MAC computer. Suggestions...
clean the pickup roller that feeds the main tray.
This is an ongoing problem with this printer, even in the single function printers.
I used a toothbrush and water, scrubbing horizontally.
Jul 05, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Printer fails to pickup paper out of paper tray
Use a soapy product suck as fantastic and clean the rubber rollers thoroughly.
They may be getting slick and in need of replacement also
Dec 07, 2007 | Samsung CLX 3160fn All-In-One Printer
23 people viewed this question
jasbo
jasbo
