Question about Toshiba DVR670 Player
Vcr starts to play for afew seconds then shuts power of to unit toshiba dvr670ku
Then when you tun unit back on it ejects tape out of unitbut fast fwd.@fwd.rewind works@does not shut unit off dvd.works ok.
  • 883 Answers
SOURCE: Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Posted on Aug 30, 2007
  • 12 Answers
SOURCE: DVD/VCR Combo Stuck in VCR Mode
i could probably walk this one through chat at idahoredfoxusa@yahoo.com
Posted on Jun 04, 2009
SOURCE: TOSHIBA RD-XV45 DVD-VCR COMBO TURNING OFF ON ITS OWN
PROBLEM NOT YET SOLVED
Posted on Jun 21, 2009
  • 76 Answers
SOURCE: I have the Toshiba D-VR4SU VCR/DVD. When I play
try new rca cord
Posted on Jan 01, 2010
bshldn
  • 736 Answers
SOURCE: Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
Posted on May 05, 2010
Magnavox ZV450MW8 shuts off when trying to rewind.
Unplug the machine and pick it up and shake it, this will tell you if something is in there that shouldn't be or that something broke off.
So many things could be wrong that it is probably not worth fixing if it is not a foreign object inside.
May 15, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Feb 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Aug 30, 2007 | Toshiba M655 VHS VCR
Toshiba DVR670 Player Logo
220 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
