Question about Kenmore Washing Machines
Where is the filter on my kenmore washing machine model 110.24994300
A lot of lint comes out on my clothes
SOURCE: Cannot find lint filter in washing machine. Is there one?
I called Home Depot where I purchased the washing machine and they told me newer washers do not have filters any longer.
Thanks for your response.
Posted on Apr 16, 2009
  • 10865 Answers
SOURCE: Lint in the wash water/clothes
If you have a regular tub/agitator machine you can fill 1/2 with water, add two cups of white vinegar & allow it to agitate but not empty. Give the machine a break to 'soak', then agitate again. Allow the vinegar-water to sit in the tub between rounds. Do this for the whole day (on weekend?) to give the machine a good cleaning. Often soaking in vinegar will loosen trapped debris so it can go down the drain. It will clean the machine very well even if it does not stop your lint problem. Sounds like there must be some part in the machine that got clogged w/ lint or that there is a hidden lint trap. Read the instruction booklet or try to contact the manufacturer via toll free phone or internet for troubleshooting on the problem. Good Luck!
Posted on May 18, 2009
SOURCE: lint showing up on dark clothes
lint
Posted on Oct 26, 2009
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
Clothes are collecting a lot of lint when washing. Is there a lint filter? I have already tried running vinegar through a cycle.
not knowing the make and model,, I can offer you this ,, if your machine actually has a lint trap it will be located right before the pump under the machine, also,, try using a little more detergent, this helps cut down on the lint left in the machine and on clothes, if you reply to this feed i will try and locate your machine and check on the filter
Jul 24, 2011 | Washing Machines
My Kenmore 22642 washer is leaving lint all over the clothes. If i run them through the dryer, that will remove the lint... but some of my clothes don't go through the dryer. I can't seem to determine if...
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
Dec 26, 2010 | Kenmore 22642 Top Load Washer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Clothes come out covered in lint after washing
Sears top load / direct drive washers don't have specific Lint Filters.
See the Use and Care manual for these washers for hints.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0705087.pdf
Apr 12, 2010 | Kenmore 24902 Top Load Washer
Washing machine lint trap
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Lint problem
You'll need to remove the hoses from the pump and inspect the inlet strainer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 27, 2009 | Kenmore Washing Machines
Washing machine Kenmore 110
is the clothes coming out of the washer with lint on them or after they come out of the dryer ,,,, the washer doesn't take all the lent off ... the dryer does so i would make sure the vent duct is open all the way out of your house and the dryer filter is clean.
Nov 07, 2008 | Kenmore 24032\24036 Top Load Washer
Lint on clothes
The lint filter should be in the agitator. Pull the softener dispenser off the top of the agitator and check for a filter. You might even find that the agitator shaft is very dirty. Put through a warm wash with a solution of 1 cup vinegar to one cup bicarbonate of soda and let it go through complete wash. This should solve the problem.
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
