Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
Check printer mode
My printer stopped during printing with an error of "check printer mode" I can't seem to get it to work... HELP!!!
  • Konica Minolta Master
  • 6,674 Answers
My printer will print one page and stop printing in the middle of the second page.
I think you are seat only one print one time so plz check it. Go to printer option and setting. One time you check printer after your printer which mode show like active print mode, print error, hold print mode etc.
I suggest you Full uninstall printer driver and re-again install printer driver. If not solved then change printer cable.
If more help contact Dell printer Support Technician. and TechSupportPrinter expert team.
Thanks.
Jan 11, 2014 | Dell Photo 926 All-in-One Printer
My printer, HP 8500, has been trying to delete a document for hours with no apparent results. I am unable to print anything else although it does put a new document in queue. I do not get any error...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My printer won't print. It will also say "unable
Ok, for the printing part you should check the following:
-connection between printer and computer
-make sure the machine is not in power save mode
-make sure machine is online; click start, printers, choose printer and make sure 'Use Printer Offline' is unchecked
-reinstall the drivers from here: http://welcome.solutions.brother.com/BSC/public/as/au/en/model_top/colormfc/mfc5490cn_all.html?reg=as&c=au&lang=en&prod=mfc5490cn_all
Now regarding the scan error, seems to be a mechanical error. Remove and objects that might stop the scanning to proceed. Also, check the manual for Troubleshooting on the link above.
Nov 14, 2010 | Brother MFC-5490CN Flatbed Inkjet...
49.4C02 error is coming on Hp laserjet 4345 printer already latest firware updated.recentely changed printer motherboard also.
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. get more information and help Printer Error 49.4c02
Sep 04, 2010 | HP LaserJet M4345 MultiFunction Printer
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
Printer stops during print job
Please check if it is giving an error and read any instruction given on the display when this happens and follows accordingly.
Jan 10, 2009 | Gestetner Copier
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
Lexmark x5150 all in one printer
Hardware Error: 0502.
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Mar 04, 2008 | Lexmark X5150 All-In-One InkJet Printer
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
50 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
