Question about Belkin USB 20 7Port Hub (F4U022v
F4u022v The USB serial controller is not recognized in device manager
No usb ports recognized
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
Mar 25, 2014 | Systemax Venture C11R PC Desktop
Drive not recognized device
  1. Click Start, then type device manager in the Search box, then click Device Manager.
  2. Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Nov 20, 2013 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
Computer will not recognize memory card when inserted
Sep 20, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
Usb device not recognized
Could be outdated drivers.?
W 7
Sep 12, 2013 | Acer Computers & Internet
Why the windows7 cannot recognize the usb cable device of psvita
w7
Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
Transcend jf v33 usb device not recognized problem:
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers or network adapters you should see a yellow question mark? right click to reinstall drivers
hope this helps
Sep 26, 2010 | Computers & Internet
I just bought a new Gateway NV53 laptop but my P4350 Lexmark all in one printer does not recognize any of the USB ports.
Did you check whether the USB ports are recognizing other USB devices such as Microvault or Flash Drive? If all other USB devices are recognized except the Printer, then reinstall the USB Drivers. You can uninstall the USB drivers from the Device Manager and restart the Computer. The USB Devices are listed under Universal Serial Bus Controllers in the Device Manager.
Jul 10, 2010 | Lexmark P4350 All-In-One InkJet Printer
USB device not recognized
Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> Universal Serial Bus Controllers - look to see if there are any yellow exclamation marks next to any of the USB ports. If so, right-click them and select Update Driver. Good luck!
-Tha Mp3 Doctor
Feb 07, 2009 | SanDisk Sansa MP3 Player
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Belkin USB 20 7Port Hub (F4U022v Logo
76 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
