Brother laser mcf-8440/ machin error 7a
Machine error 7a on screen, "open cover" after I open cover it says close cover, when I close cover it says machine error 7a unplug and call brother
  • dardila Aug 30, 2008
    pasa lo mismo y no encuentro solucion ... ayuda!!!
  • 1,218 Answers
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
Posted on Sep 22, 2010
  • 1,113 Answers
And brother would say...7a= Main motor does not synchronize with the reference clock, .... check.....
• Thermistor ASSY
• Main PCB
• Engine PCB
• Main motor
and fix i'd say is to replace main board.
Posted on Nov 09, 2007
Just installed a new drum unit in my Brother DCP1000, and it's still reading "Replace Drum soon"
heya!
this stands for brother mfc-8440 as in the title.
you need to reset the "drum counter" of your printer..
to do so try one of those
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
Brother Fax Machines:
Open the front cover. Press the CLEAR/BACK button. Press 1, when the display shows accepted.
Sep 19, 2011 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 Machine Error Code 7A - tried to print something and machine stopped, beeped and gave me this code. No resolution from Brother other than to have a tech come look at it. Any insight...
Hello thanks for using FixYa
Error code 7A occurs in different forms and they are linked directly to errors caused due to calculations as detected by GPU, however, it is still doubtful what exactly cause these GPU errors in hardware and the errors in WU. Keep in mind that this error code could also suggest that the main PCB is broken.
For the error code 7A to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition. If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor. In this case, make sure that there is no mechanical load present on the main board. While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | Brother MFC-8440 All-In-One Laser Printer
WHEN I TURN ON MY MACHINE BROTHER MFC 8440 I SEE ON THE SCREEN ERROR MACHINE 6A I NEED A SOLUTION
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
Jan 08, 2011 | Brother MFC-8440 All-In-One Laser Printer
What is error 7A
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock.
http://www.fixya.com/support/t5660619-7a_error
Jun 23, 2010 | Brother MFC-8440 All-In-One Laser Printer
Machine error 7A
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock. for more information and help........
Mar 04, 2010 | Brother MFC-8440 All-In-One Laser Printer
Canon fax machine says "cover open" and won't do anything till the msg is cleared. How do I clear this msg when my cover is in fact closed?
You may need a new hinge, the one in the left rear breaks and gives that error when the scanner cover doesn't go all the way down. the hinge is part #
LP2403001.
Dec 04, 2009 | Brother MFC-8440 All-In-One Laser Printer
When i turn on my brother mfc 8440 it is saying
Oct 01, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc-8440 printer/fax
you need to buy the left cover hinge, how ever so that you can use the machine, by the cover there is a sensor button, tape it down and you can still use the adf
Nov 13, 2008 | Brother MFC-8440 All-In-One Laser Printer
2,555 people viewed this question
k24674
Marvin
Marvin
