Question about Proform Exercise & Fitness
Proform treadmill runs wide open only
Treadmill runs wide open when i hit reset button, no controls work
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 16 Answers
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
  • 64 Answers
SOURCE: Proform 450 X treadmill powers on, but trips current when started
There could be a combination of problems. I would first start with disconecting the motor leads and see if it trips the breaker. Then elevation motor would be next if no change from disconecting motor. More than likely it's a motor issue.
Posted on Jun 08, 2009
SOURCE: Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Posted on Apr 18, 2010
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Posted on Jun 01, 2010
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
My Reebok i run treadmill is not working.
If you wish to get some details about treadmill repair check the bellow added link.
www.electro-medical.blogspot.com
Jun 28, 2016 | Reebok Exercise & Fitness
I plug my healthriderpro H 450i into a outlet that had no ground.It work for a little bit but turn off and nothing happens when I hit the reset button.What could be the problem?
The ground on the outlet is only for safety reasons. It will not affect the operation of the machine. Check for a fuse on the control board.
Nov 19, 2014 | HEALTHRIDER Pro H450i Treadmill HRTL61706
Why reset button not working in my reebok treadmill t4.2
tes the reset button for open or faulty and replace. tight the connection, or see if there are some loose wires and resolder. and try again.
However you can reset disconnecting the power cord by 30 seconds. and try again.
God bless you
Aug 01, 2013 | Reebok Vista Treadmill - RBTL13305
My precore 9.43 starts to run then in 5 seconds turns itself off. Says ERROR- nothing more.
proceed according and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
Jan 25, 2013 | Precor 9.4 Treadmill Motherboard Motor...
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
When someone is running on the treadmill it loses power and i have to hit the fuse reset buttons
sounds like your motor is on its way out but first check the control module fans are not plugged and causing over heating. These are located under the hood usually a large black or grey box.
May 20, 2011 | Cybex International Exercise & Fitness
My reebok treadmill makes only three beeps when you hit the sensor buttons
Plug in power cord, remove key, hold down speed+ and stop buttons, replace key, release buttons, press stop once, press and hold speed + until max. treadmill will run to top speed (s9.80 should read out 11.8 to 12.5.) It took a couple of times to get this to work for mine, but now it is OK. If unit does not run after several attempts then the console is probably bad and will need to be replaced ($410). Get another treadmill ! If it does run the console may still beep - problem is with IFIT card. You can get rid of the beeps by opening the console and unplugging the IFIT cable from the computer card if you want.
Feb 06, 2011 | Sport & Outdoor - Others
I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
Aug 13, 2010 | Life Fitness 9100 Next Generation...
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
Mar 31, 2010 | Life Fitness 9500HR Next Generation...
Exercise & Fitness Logo
44 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
