Question about Belkin USB 20 7Port Hub (F4U022v
F4u022 not recognized in device manager - Belkin USB 20 7Port Hub (F4U022v
Laptop not recognizing device when plugged into laptop how to fix
The computer is not recognizing the device because the appropriate software or driver is not installed on the device.
Most of the time when you connect a smartphone into a compatible laptop the device drivers or software automatically install, so the laptop may recognize the smartphone.
Here are some possibilities as to why the device is not recognized.
1) The USB port is bad.
2) The USB port is not activated
3) One of the devices does not support the other
Here are a few possible troubleshooting solutions:
1) Go to the smartphone manufactures website and download and install the updated device driver and software then plug in the device to see if it is recognized.
2) (if Windows OS) Go to the Device Manager to see if the device is showing up when it's plugged in. If you see the device in device manager right click the device and choose to update the driver.
3) (if Windows OS) Additionally, in device manager you can check your device's USB ports to see if there is an issue with the ports that may be resulting in the smartphone not being recognized. You can choose to re-enable the USB ports or update the software for the USB ports.
Hopes that helps resolve your issues.
Open Device Manager Windows Help
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Nov 07, 2015 | Acer Computers & Internet
Drive not recognized device
  1. Click Start, then type device manager in the Search box, then click Device Manager.
  2. Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Nov 20, 2013 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
Driver download
If your computer does not recognize the USB device, first try method 1 to work around this issue. Method 1: Initiate recognition of the USB device by using Device Manager To initiate recognition of the USB device by using Device Manager, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Click to select your computer as the location for the scan. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method resolves the issue, you are finished. If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub Note If you perform the following procedure, you may also reduce the battery life on a portable computer. Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Expand Universal Serial Bus controllers. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed. Click the Power Management tab. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK. Repeat steps 3 through 6 for each USB Root Hub in the list. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method does not resolve the issue, go to method 3. Method 3: Restart the computer To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device. If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus Back to the top ' Give Feedback
Nov 11, 2013 | Targus AMW05US Mouse
Why the windows7 cannot recognize the usb cable device of psvita
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
Some USB that are attach to my pc are not recognized.
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
  4. Close the Device Manager window.
If this method does not resolve the issue, go to method 2. uparrow.gifBack to the top Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3. uparrow.gifBack to the top Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Aug 14, 2011 | Computers & Internet
Gateway 310 s won't recognize a cd
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Externals not recognized by computer.
Go to your control panel open up 'administrative tools' Open Computer management, then choose disc management instead of device manager. Make sure that you have the drives pluged in and connected before you do that. All connected drives formatted or not that are in working order should show up under disc management. If they are not showing up they are not compatable. Make sure that they are marked as active and format them if they need to be formatted. Do so by right clicking on the drive in the disc management window.
May 12, 2009 | Hitachi External 20GB Mini Slim Hard Drive...
IRiver Music Manger not recognizing iRiver player when connected
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Jan 23, 2009 | iRiver iFP-795 MP3 Player
Belkin USB 20 7Port Hub (F4U022v Logo
95 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
