Question about BYTECC (BT144) External Floppy Drive
Bought a Bytecc external floppy drive for my xp cant get it to work i put the disc in but nothing happens
    Novelist:
  • 242 Answers
Look to see if it shows up in your device manager. If there, delete and reinsert it from scratch. See if the drive hums once when you plug it in (recognizing it). USB cable might be broken inside if it does not register.
Posted on May 29, 2014
My desktop PC XP OS can detect TDK FDD-100 external floppy drive ,but cannot read files inside. How can I solve my problem?
The disc may be corrupted :( In most cases external floppy drives work just fine but the disc they are reading is old. Shelf life of floppies is really only 3 to 5 years. After that you really can't trust that you'll be able to read them. I've had discs up to 10 years old that I can still read, but others that are only a couple years old I can't. Try plugging the floppy into another PC to see if that one can read it. Recommend trying it on a newer PC (Windows 7 or 8)
Mar 15, 2015 | TDK Fdd-100 Usb External Floppy Drive
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
Instructional manual
It should just plug in and work. To the best of my knowledge these come with no manuals.
Jan 09, 2013 | BYTECC (BT144) External Floppy Drive
I have windows 7 and the Bytecc bt-144 will not work. the drive is not recognized and when i attempt to update it with the driver from the Bytecc web page the computer say the driver isup to date and will...
you might be installing the driver through the right process
click start right click on computer select properties device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Jul 25, 2011 | BYTECC (BT144) External Floppy Drive
My BYTECC USB Portable Diskette Drive was installed on my Dell Inspiron 5305 computer. However when I moved, it became unplugged. I do not know where to plug it into the computer.
if you look at the picture you can see where the usb ports are thats where the usb lead from your drive goes
sepang24.jpg number 10 is the usb ports John
Feb 02, 2011 | BYTECC (BT144) External Floppy Drive
I wanted to copy some files from a floppy disc to my external hard disc formated for Mac but there seems to be mechanical problems and it says it is unreadable and wants me to reformat it. I bought a new...
Copying files from Floppy Drive to External HDD.
01. Ensure that both Floppy drive and External HDD are configured properly in the machine.
02. Sometimes if virus affected the files of floppy drive, will not copy the full files.
03. Close the small led in the floppy top right side and check once again.
04. In start program, type coimmand and the dos prompt with Drive will appear.
05. keyin Dir A: and see it reads all files.
06. There also it gives error, you cannot copy these files to External HDD.
07. Try to use some other floppier which is already formatted.
08. Ohrr solution is just copy all these files from the floppy drive on to C: and copy the same files after creating a folder in C Drive.
09. Check the Interlink cable is also working fine.
10. If the problem not solved, please call authorized system service engineer to sort out the issue..
Mar 05, 2009 | Imation (01946) External Floppy Drive
Installation of BT-146
Yes, you need to plug in a 4 pin FLoppy Molex connector. Your power supply should have at least one. The power connector is right next to the Floppy Drive connector.
Also, the Floppy connector goes in with pin 1 (The red stripe) to the left looking at the unit from the back (furthest away from power).
There is no manual to speak of.
Jan 09, 2009 | BYTECC (BT144) External Floppy Drive
Nexxtech External Floppy Driver Problem
Normally windows will install any driver for a usb floppy drive automatically. If it needs one. I'm surprised that it hasn't just worked by plugging it in as there cheap floppy drives over purchased have all just worked without the need to install drivers on win xp and higher. Remember you won't see the drive appear under my computer until it has a disc inserted in it though.
Jul 17, 2017 | NexxTech USB External Floppy Drive (NEFD2)...
Software for 500GB
I don't think BYTECC sells complete external hard drives. But they do sell the enclosures. People buy the enclosures and install a hard drive in them and, now you have a working external hard drive. I have don't this before, but I have never used BYTECC before. You can download the drivers for there enclosures at there website:
http://www.byteccusa.com/
They have several different versions, Just pick the correct one, hopefully the enclosure has some markings or a sticker identifying the model.
Nov 17, 2007 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
BYTECC (BT144) External Floppy Drive Logo
165 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
