Question about Air Conditioning and Heat for Audi A6
Air con and radio packed up at the same time - Air Conditioning and Heat for Audi A6
Trying to replace a radio in an Nissan Almera n16 (2003), I Is it possible to replace this radio, or because the dash radio/Air-con is all the one?
Look at the bezel around the radio. It just pops off. If it goes up around the instrument panel, look for screws around there. Under the bezel, there will be screws to remove.
Sep 07, 2015 | Nissan Cars & Trucks
My 2000 Toyota Echo will not let me put on air or air conditioner idles high at low speed and at park or stop?
It is normal for the idle to increase when the air con is switched on. There is a fuse in the engine compartment - I-UP (idle up)
May 05, 2014 | 2000 Toyota ECHO
Mercedes E300 Elegance. 1998 model. Intermittent supply to magnetic clutch on air conditioner pump. I have taken temporary supply from cigarette lighter socket. and air conditioner works fine. What can be...
You seem to have a bad connection between the air con switch and the clutch. trace the wiring backwards from the clutch to the air con switch. A wire or connection may be corroded, damaged or chafed.
Aug 28, 2013 | Sony 4.72" x 2001' Wax/Resin, TR4085plus...
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
My car's air-con (Tuczon 2007) suddenly stopped thrice! First time (only after 1 year) brought it to a service center and told me its relay just needed cleaning. 2nd time same thing; 3rd time told me...
Hello! You can search replacement part on eBay
Here link for example https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xtucson+2007+air+con+swich.TRS0&_nkw=tucson+2007+air+con+swich&_sacat=0
Jun 19, 2017 | 2007 Hyundai Tucson Limited
My radio does not working after my mechanic fixed the aircon of my car, 2002 mitsuibishi lancer, standard.
its possible that he hasnt connected it back up after working on your air con,especially if hes worked on the dash area,as thats the most likley reason its not working .Even a blown fuse due to any electrical work involved with the Air Con,but nothing to worry about as in terms of major .But you need to find out if the radio is connected or a small earth wire is off
Nov 28, 2009 | 2002 Mitsubishi Lancer
97 land cruiser wet carpet passenger side . have blown clear sun roof drain vents ..air con is dripping ok pipe outside floor pan ...no coolant usage ..no smell to wet carpet ... dried carpet drove last...
Does the car have climate control air/con?If so,air/con may still be coming on at different times.I would double check the air/con drip tray.Sometimes it has 2 pipes if the tray has split levels.One may still be blocked.(Does the car have a built in fridge?)Hope this may help
Sep 05, 2009 | 1996 Toyota Land Cruiser
Air con rattles
my friend i don't like ford they are fix or repair daily or find on the rouad dead f.o.r.d, how ever it sounds like u have two diffrent problems the bushing on the air con is what is making the noise and the radio is a bad contact of the radio not two of the same but two problems. for the nosie install a new compressor, the speaker noise try finding that loose ground wire or install a new radio. and next time if i was you i would shop for the car like a rock, gmc period.
Jul 06, 2008 | 2003 Audi TT
AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Air Conditioning and Heat for Audi A6 Logo
14 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Tom
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
