Question about BIT Garden
Have a mini cat excavator track promply only on one side
4 Suggested Answers
  • 7 Answers
SOURCE: Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Posted on Jul 02, 2009
  • 51 Answers
SOURCE: warning light on in cab 235 c cat excavator
have you checked the level could be low or change the hydraulic filters they could be blocked. or it is just a service light.
Posted on Jun 13, 2012
  • 42561 Answers
SOURCE: What causes a mini excavator (Yanmar B27) on
probably not--This sounds like uneven pressure from the hydraulic pump or problems with the drive motors. Check that the hydraulic oil filter is in good condition (not blocked) and have the pressure in the hydraulics checked.. Have the hydraulic controls checked for correct operation. (if electric controls check for voltage problems to the solenoids and if manual check for control valve problems)
Posted on Oct 05, 2014
How to remove front idler on bobcat 331 mini excavator
Bobcat 331 Mini Excavator, Front Idler Assembly
www.loaderpartssource.com/bobcat-331-mini-excavator-front-idler-asse...
Loader Parts Source, Inc. offers this Front Idler Assembly for Rubber Tracks (W/ Holes in idler) for replacement on the Bobcat 331 Mini Excavator. Serial Number ...
Bobcat Idler: Construction Equip Parts ' eBaywww.ebay.com/bhp/bobcat-idlereBayBobcat 325, 328, 331, and 334 Front Idler - Undercarriage, Mini Excavator, ... BobcatT140 T180 T190 T200 T250 T300 T320 T650 T630 T750 864 Front Idler ...Undercarriage Parts Can Help You:Eliminate Unwanted Machine Downtime.Front/Rear Idlers - Mini Excavator Partswww.miniexcavatorparts.com/productcart/pc/viewCategories.asp?...14Aftermarket front and rear idlers are available for Bobcat track loader and mini excavators, Kubota miini excavators, and ... Aftermarket Bobcat® Front Idler - Bobcat CTL ... Aftermarket Idler - Bobcat 325 328 331 334 430 335.
Dec 25, 2015 | Mini Cars & Trucks
What do all the instrument lights stand for on my kubota rx 302 mini excavator
kubota owners manual for rx 302 mini excavator pdf - P(1 ...
www.search-document.com/.../kubota-owners-manual-for-rx-302-mini-e...
Looking for: kubota owners manual for rx 302 mini excavator ... 3.4 Flow testing, regulating & setting the excavator OEM relief valve. ... of the parts, even those ...
Manual KUBOTA RX 302 - User's Guide KUBOTA RX 302 ...
www.manuals.club/results_alpha.php?search=KUBOTA+RX+302
KUBOTA > KUBOTA > RX 302 > 10 results for : KUBOTA RX 302 ... KUBOTA - KX 008 (KX008) Mini Excavator (User's Guide in French) · KUBOTA - K008-3 Mini
Oct 27, 2015 | Garden
My mini excavator 334 lost hyds to boom and tracks. blade still goes up and down .the red ! light is on
could be a bad solenoid find out which on works that solenoid , make sure you are getting power to it could also be fused ck that first , cannot be to much to fix ,get a manual of it to ck the solenoid position
Nov 25, 2014 | Mini Cars & Trucks
Cat excavator
please finish the question but taking a guess at it its probably a check vale has gone out most liklely check valves seem to go out easy on cat excavator it can be fixed in the field or hydralics low on fluid replace. look for leaks this is just taking a guess with unfinished question
Sep 01, 2014 | Garden
Caterpiler 320c chin excavator
You can Online Wholesale caterpillar 320c ads from category Caterpillar excavators for sale coming from China. It may occure problem so you need to consult with neer repair store.
Jan 12, 2014 | Cars & Trucks
Hitachi excavator
Hi I have the same problem,zx16hitatchi mini and I've been told it is track motor needs replacing? Or it could be a seal gone in one side of the spool valve for that track, on the hydraulic pump? Ask a local digger parts dealer for a good repair shop in your area.
Dec 03, 2013 | Hammering
Looking for the switch to change from cat controls to john deere controls on a cat 315 excavator
Hey Rawhide.....have a Cat 315 myself and looking to do the SAME thing (just got it yesterday). Talk about confusing. I'm used to JD too, so if you hear.....please let me know and I'm going to try to find out from the guy I got it from 2morrow. I believe that it's a simple and easy fix but you never know. My email is franandnan@netzero.net . Use Cat 315 in the header. Thanks (or anyone else too) Fran
Nov 02, 2009 | Kettler Caterpillar Excavator
Kubota kx91-2 excavator keeps stalling.
Check fluid levels and viscosity of fluid. The valve spools may be also sticking. Remove, clean and replace them as well.
Dec 18, 2008 | Plumbing
Garden Logo
Top BIT Garden Experts
Bill Boyd
David Hoover
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a BIT Garden Expert? Answer questions, earn points and help others
