Question about 2001-2004 Ford Ecape 4Dr Outcast Front Bumper
Spray starting fluid
Start only with starting fluid and keep running, and accelerate well only have to spray starting fluid
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Is check engine lite on?
Posted on Feb 10, 2014
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
MY homelite BP-240 backpack blower will not run with out the assist of starting fluid. First I tried to start it with just pushing the gas primer bulb. after no success I just sprayed start fluid . It will...
dont spray starting fluid in there to start it has to have a gas oil mix for the piston to have lubrication it will scar or burn the piston and cylinder wall check the fuel lines to see if they need replaced and the fuel filter also the priming buld to for cracks etc.
May 18, 2011 | Homelite Consumer Products Backpack...
Will not start. I think it's a problem with the carburetor but don't know where it is and can't find it in the manual.
Do this. get a can of starter fluid and a helper. spray some starter fluid into the air filter and start it. have your friend keep spraying the starter fluid to keep it running til the problem clears and it runs on its own. If this doesn't do it, that carb will have to be rebuilt. J.
Jul 13, 2010 | Garden
Blower has gas also sprayed gas into carb and wont start???any ideas??
hi. get a can of starter fluid and a helper. remove the air filter. have your helper spray a little fluid into the air cleaner and then start it up... keep spraying enough fluid to keep it running for at least two minutes to clean the engine of any crud. Joe
Jun 17, 2010 | Poulan Featherlite Gas Blower, with Low...
94 pontiac with 5.7L, wont start. Fuel and fire are there and a new computer, still won't start
These distributors are bad to have problems,where they are located,the pick up coil is the most likely problem,the pick up coil pulses the injectors,I assume this is your problem,spray starting fluid in the intake,and see if it hits,it will not run long,do not move accelerator ,just spray in a vacuum port where the fluid can **** threw to the cylinders,if it hits,then the pick up coil in the distributor is the problem.
Jun 07, 2010 | 1994 Pontiac Firebird
Fuel problem, wont start
the pump is part of the filter/separator not in the tank no fuel will come out if filter is removed make sure there is fuel in the upper filter if there is the pump is ok it might be an oil pressure concern
May 10, 2009 | 2004 Ford F250
1997 dodge 3.5 fast idle can not slow it down. at start running about 2.5rpms. i can drive down the street at 35mph without touching the gas pedal.
Sounds like a vaccuum, or gasket leak. Easiest way to diagnose is to get a can of starting fluid and spay it around any vacuum hoses and intake area while it's running. Be careful! Starting fluid is extremely flammable!
If you notice an acceleration, or de-celeration while spraying the starting fluid, you should be able to pinpoint the leak.
Apr 16, 2009 | 1997 Dodge Intrepid
2001-2004 Ford Ecape 4Dr Outcast Front Bumper Logo
65 people viewed this question
Top Prem Dey Vehicle Parts & Accessories Experts
rdjagger
alwaysreddy
Paula Hamilton
Are you a Prem Dey Vehicle Part and Accessory Expert? Answer questions, earn points and help others
