Question about dr. Tech WA-1070 Wireless Advanced Weather Station with Solar Transmitter
Out side unit works with solar panel unhooked but not when solar panel is hooked up and out side humidity doesn't work at all please help
My solar panel is not working in my birdbath fountain. When I did a troubleshoot it said to test the unit with the fence unhooked. What is the fence?
Check the pump to see if there is a blockage stopping the impeller from moving. If you have a volt meter, measure the output of the solar cell in bright daylight to see if it is producing the correct voltage.
Jun 19, 2016 | Solar Electrical Supplies
How do i hook up gallagher s20 solor fence
Jill, If there are only two wires, and the battery is already connected to the solar panel, and the solar unit or the fence is not connected to anything else, then it doesn't matter which is which. However, if you are hooking to the battery or to something else, then it DOES matter. That said, the universal color code is green for ground and red for hot.
Good luck.
Jun 21, 2012 | Saws
No charge, is it battery or solar panel, how do I tell
if the unit is not produceing a charge during daylight then it is the unit. the DF-SP-LI will produce full power under sunlight alone. test the unit with the fence unhooked.
Jun 01, 2012 | Parmak Solar Fence Charger
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
I have a solar pump kit using an OASE Aquaflow 1500 submerged unit .The pump will spin when connected to a car battery but when attached to my solar panel which is producing 21 v on open circuit it will...
Hello Phil, what is the size of your solar panel? This pump draws 17 watts so, your panel must be 17 watts or greater. Remember a solar panel only puts out full power when in direct sunlight and facing the sun directly. You can read 21 volts but your amperage may not be full and this is why your pump is not running, not enough amps. I would recommend a minimum of a 20 watt panel.
Feb 14, 2011 | Plumbing
Will not hold a charge
Time for battery replacement!
Nov 05, 2009 | 2001 Yamaha V Star 1100 Classic
My pool isn't heating much even in extreme heat.
if you pump is dual speed,try turning to lower speed and water will stay in solar system longer,thus having a higher heat gain
Sep 02, 2009 | Solar 2 PANEL DELUXE SOLAR HEATING SYSTEM-
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Sep 13, 2008 | Goldstar DH304 Dehumidifier
dr. Tech WA-1070 Wireless Advanced Weather Station with Solar Transmitter Logo
Top dr. Tech Measuring Tools & Sensors Experts
Lawrence Oravetz
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a dr. Tech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
