Question about Electrolux ICON Professional E30SO75FPS 30" High-Speed Wall Oven with 1.1 cu. ft. Convection Oven, 1000 Watts, Manual Clean and Glass Wave-Touch Controls
Electrolux Microwave door glass shattered spontaneously-need replacement
The microwave was not being used when I heard a sound. We searched to see what happened and it was the microwave glass that has shattered. This is an Electrolux Icon dated July 2012. Model E30S075FPS. Will we be able to find a replacement door? or does the entire microwave need to be replaced? Thank you.
  • 1214 Answers
SOURCE: How to operate Electrolux Microwave oven Model EC9055?
Here's the manual -
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0708331.pdf
Posted on Jan 24, 2009
ginko
  • 19396 Answers
SOURCE: Electrolux Microwave EMS 2487x not heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
milten1
  • 1304 Answers
SOURCE: Handle on Frigidaire Microwave broken.
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Posted on Oct 28, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire (made by Electrolux Home Products) over
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 19, 2010
  • 3230 Answers
SOURCE: Need user's instructions manual for Electrolux
Well you may please follow the link below to get your manual -
http://www.electrolux-ui.com/UM%5Cmaster.nsf/SearchFrame?OpenFrameSet
Good Luck!!
Thanks for using FixYa!!
Posted on Nov 23, 2010
Why did the glass in microwave door shatter melt?
A spoon in the coffee the cup had metal parts
Feb 20, 2015 | Frigidaire Microwave Ovens
Help need replace glass panel in pvc
This door is radius and would be difficult to replace. Repair clinic claims the part is due in at the end of this month, I wish you luck on your search. I have not seen someone make this correctly as the metal supports at the bottom are attached to the glass and the stainless steel outer panel is just a panel stuck to glass.
Good luck
Feb 05, 2014 | Jenn-Air Microwave Ovens
Roper microwave has broken glass in the door
Whatever you do don't use the microwave until you replace the door. You run the risk of possibly shattering the glass or being exposed to dangerous microwaves from the oven. Get on the Roper web site and find a replacement for the door. You never know there could be a recall for safety issues on your particular model.
May 02, 2010 | Microwave Ovens
The inner door glass shattered and now no power
There's a safty switch which prevents the unit from operating if the door isn't fully closed. When the glass shattered a small piece may have blocked the switch from operating properly. Check around the door seals for any irregularities.
Mar 22, 2010 | Neff H7871N2GB Convection / Microwave Oven
GE Microwave/Convection Oven - Door Glass Just Exploded!!!
This happened to us 3 weeks ago with our 3 year old Kitchenaid microwave. Several hours after its last use it just shattered. In doing research I discovered that this has also happend with GE microwaves, all 3 years old. The cause seems to have been a batch of defective glass supplied by a third party. Whirlpool was very quick to cover the cost of the replacement, even though our microwave was out of warrantee.
Aug 27, 2009 | GE JEB1095 Convection/Microwave Oven
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Microwave door shattered
Give is the entire model # on the sticker inside the microwave and I should be able to help.
Oct 20, 2007 | Neff H7871N2GB Convection / Microwave Oven
Electrolux ICON Professional E30SO75FPS 30" High-Speed Wall Oven with 1.1 cu. ft. Convection Oven, 1000 Watts, Manual Clean and Glass Wave-Touch Controls Logo
21 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
